Manual
Old Aug 26, 2005 | 09:34 PM
04redvertZ51's Avatar
04redvertZ51
Default Manual
hey guys, i have driven my dads vette a few times, but one thing i cant quiet get is starting off from a standstill...can anyone please, Please, tell me the how u should launch a manual the correct way...thanks
BTW im 16 yrs old, and i want to learn to drive a stick b/c the car im gettin is a stick shift.
Thanks guys!
-Mike
Old Aug 26, 2005 | 09:43 PM
wolfmd's Avatar
wolfmd
Give it more gas!
Old Aug 26, 2005 | 10:21 PM
04redvertZ51
ANYBODY ELSE?! lol
Old Aug 26, 2005 | 10:43 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Rev to 5000 rpm. Dump clutch. Repeat.
Old Aug 26, 2005 | 10:44 PM
Vic Montaner's Avatar
Vic Montaner
Ask your Dad?
MY1STPEWTER's Avatar
MY1STPEWTER
Practice is the main thing. You just want to slowly release the clutch while giving it just a little gas. Now this is on flat ground. If you were to be at a stop on a steep hill you'd have to be a little quicker with each to keep from rolling backwards. It's really not hard, just like anything else you just need to do it several times. Kinda like learning to whistle, once you get it you realize how easy it is. Just find yourself a empty parking lot and get some practice, I bet you have it down before you leave.
Old Aug 26, 2005 | 10:54 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Originally Posted by Vic Montaner
Ask your Dad?
Old Aug 27, 2005 | 03:24 AM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
If you are careful, you can actually let the clutch out while the motor is just idling. Actually the Vette is not that hard a car to learn to shift on. It really is a balance between the clutch foot and the gas. Most folks make the mistake of giving it too much gas or letting the clutch out too fast.
As I mentioned, on level ground you should be able to slowly let the clutch out while the motor is idling. Try it in a parking lot...if you can get the hang of it then adding a little throttle later will be a lot easier. The key is letting the clutch out slowly. If you do it too fast you will kill the motor.
Hope this helps!
To Manual
