help with rim weights
Old Aug 26, 2005 | 09:49 PM
I X L R 8's Avatar
I X L R 8
Default help with rim weights
currently I have the wagon wheels , and the opportunity has presented itself for me to purchase Mikes rims, 5 spoke.
would anyone know if the spoke rims are lighter than the wagon wheels?
its a given they are better looking.
but im curious as to weight.
any help will be appreciated.
mike if you read this i'll let you know something tonight via pm's, and thank you for giving me first crack at them
much appreciated.
Old Aug 26, 2005 | 10:06 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
From Sticky at top of page:
Wheels
19.2 lbs, front; 21.4 lbs, rear --- 97-99 OEM wagon --- Source
22 lbs, front; 29 lbs, rear --- 97-99 OEM wagon --- Source
17 lbs, front; 19.5 lbs rear --- 97-00 OEM magnesium --- Source
17.5 lbs, front; 19.5 lbs, rear --- 97-00 OEM magnesium --- Source
18.08 lbs, front; 20.06 rear --- 00 OEM standard, thin spoke, high polish --- Source
17 lbs, front; 20 lbs, rear --- 00 OEM standard, thin spoke, painted, no sensors or centercaps --- Source
16 lbs, front; 20 lbs, rear --- 01 OEM standard high polish --- Source
19.6 lbs, front; 21.4 lbs, rear --- 01 Z06 forged --- Source
19.2 lbs, front; 21 lbs, rear --- 02-04 Z06 cast/spun --- Source, Source
24 lbs, 18x10.5 --- 00+ repro high polish --- Source
28 lbs, front; 32 lbs, rear --- Z06 chrome repro --- Source
23 lbs, front; 26 lbs, rear --- Z06 chrome repro --- Source
23.5 lbs, front; 24.5 lbs, rear --- Z06 Motorsports, polished --- Source
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear --- PWO --- Source
22 lbs, 18x10.5, 58mm offset, front --- HRE 545 w/clear center --- Source
27 lbs, 18x12, 74mm offset, rear --- HRE 545 w/clear center --- Source
Old Aug 26, 2005 | 10:08 PM
I X L R 8's Avatar
I X L R 8
i cant make sense of that.
there are 2 different types of wagon wheels it seems......with two different weights.
same for the magnesium................thats why i cant tell which is lighter.
i really want these rims
Old Aug 26, 2005 | 10:30 PM
3C2's Avatar
3C2
I just switched out to mags and my 1999 chrome wagon wheels were 19.5lbs for both fronts and 21.5 for both rears. I weighed each one and they came out to those weight on my bathroom scale. My mags weighed 17.5 each for the fronts and 19.5 each for the rears. Just an FYI, the 2 lbs that I lost from each wheel is VERY noticeable so it's highly desireable to lose weight in those areas.
Old Aug 27, 2005 | 01:24 AM
I X L R 8's Avatar
I X L R 8
thank you sir.
that is all i needed to know
Old Aug 27, 2005 | 01:30 AM
I X L R 8's Avatar
I X L R 8
Additionally, the sticky notes should be updated with true and correct rim weights on an average.
this does contribute to performance. Albeit a slight difference.
Old Aug 27, 2005 | 02:06 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Are you serious? What did you feel was the difference? Did you put different tires on at the same time?? 4 lbs per set of wheels make a significant difference?? WOW...
Got some data to back that up? Now you've made me curious... skeptical but curious...
Old Aug 27, 2005 | 07:32 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I'm not doubting what you're saying since I have no first hand knowledge yet, but 2 pounds in each corner makes THAT much of a difference?
Old Aug 27, 2005 | 08:39 AM
I X L R 8's Avatar
I X L R 8
good to see you on my thread Eric.
Hope youre doing well.
Old Aug 28, 2005 | 08:30 PM
3C2's Avatar
3C2
The two pounds that were lost were unsprung so I think that's what made the big difference. I drive my car 40 miles 5 days a week so I get lots of road time to see how the car handles. I feel the wheels recover faster and regain contact with the road when I hit small bumps. I feel more in control in these situations. The acceleration is still pretty much the same but it just "feels" more responsive from a dig. I just swapped the old tires off my wagon wheels on to the new mags too, so no extra weight added or lost there. While I agree that two lbs lost elsewhere would probably not even be noticed, at the wheels they feel wonderful. I love the mags
Old Aug 28, 2005 | 08:38 PM
tlaselva's Avatar
tlaselva
Be very careful of rotating mass, such as rims, tires, rotors, shafts, etc.
For every 1 lbs. of rotating mass, it effects your car similar to 4 lbs. of static weight.
So even something nominal like 10 lbs. off your rims total, can have a noticable difference.
To help with rim weights
