zr1 wheels.
Old Aug 28, 2005 | 03:05 AM
NSTG8R's Avatar
NSTG8R
Default zr1 wheels.
think it would be wrong to do ZR1 wheels with c5 center caps on a c5?
kinda like the white tigershark did.
Old Aug 28, 2005 | 03:11 AM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
I would rather be... Well you know the rest.
Old Aug 28, 2005 | 03:55 AM
Lancer033's Avatar
Lancer033
It's pretty common to use ZR1 wheels as track wheels, I'm actually thinking about picking us a set myself, but I don't think the style is good for normal use. If you like the look go for it. I'm sure you can find several pictures of it to help make up your mind.
If memory serves me well, the ZR1 offset will make the wheels stick out a little bit, but the GS offset works fine. You might want to do a little research on that.
Old Aug 28, 2005 | 09:09 PM
RobWilson's Avatar
RobWilson
It wouldn't be wrong, but I think you are going to need a special offset to keep them from sticking out. I had some on my '99 SS, the rears were the GS offset. We put them on my friend's '00 Coupe and they stuck out too far in the rear with 315 wide tires on there.
Old Aug 29, 2005 | 02:42 AM
Tiger Shark's Avatar
Tiger Shark
Hi,
I think you're referring to the White Shark. Those are actually Fikse custom wheels:
Old Aug 29, 2005 | 03:11 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
To zr1 wheels.
