lectrical help
Old Aug 28, 2005 | 12:16 PM
Mr. Blue's Avatar
Mr. Blue
Default lectrical help
The courtesy lights in my 98 stopped working - all of them. The circuit is protected by a mico-relay. This is a little plastic box with 4 pins on the bottom, and it's located in the passenger side footwell fuse box.
My question is, do these go bad very often, and if you put a new one in backwards, will it be damaged? I did just that, and the lights still don't work. The door switches seem OK, since the lights in the window controls and door lock switches come on when the doors are opened.
Any help or thoughts on this would be appreciated.
Old Aug 28, 2005 | 12:26 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
After you changed the relay ... did you check and/or change the #2 and #42 fuses in that same box?
Old Aug 29, 2005 | 11:26 AM
Mr. Blue's Avatar
Mr. Blue
42 IS the microrelay, which i changed. I'll check the #2 fuse tonight. Thanks!
To lectrical help
