[Z06] busted clutch pedal spring !
Old Aug 28, 2005 | 09:13 PM
Gasser82's Avatar
Gasser82
Default busted clutch pedal spring !
Found part of a spring on the floorboard under the clutch pedal.Looked at the clutch pedal and there is supposed to be two springs attached to the pedal, not now. anyone ever have this happen and can it be replaced without having to compress the spring.
Old Aug 28, 2005 | 09:52 PM
Chris.Shea's Avatar
Chris.Shea
you dont need it.... its for the old guys with weak left legs move the pedal. alot of guys pull thiers off when they get sticky pedals and it seems to be a temporary fix. i dont see why any harm can be done to the car without it.
Old Aug 29, 2005 | 02:01 AM
TheDVS1's Avatar
TheDVS1
I removed my spring and noticed improved modulation of the clutch pedal. The increased effort is barely noticeable. Just save yourself a headache and leave it off.
Old Aug 29, 2005 | 02:18 AM
EB03Z's Avatar
EB03Z
Default spring
Had same thing happen on my 03Z. Piece of spring in floor board. However, My clutch pedal was not pushing all the way out and I was told at the dealer that the spring pushed the pedal oput. he advised that since the pedal was hanging down an inch as a result, I probably had clutch burn and they put in a entire new clutch asembly flywheel and all. Thought that was great until I got it back and had severe vibration and had to take it to another dealer to get the correct install.
Old Aug 29, 2005 | 02:36 AM
Vegas Vette's Avatar
Vegas Vette
You done need it I removed mine a while ago and have had no problems at all.
Old Aug 29, 2005 | 03:55 AM
Chris.Shea's Avatar
Chris.Shea
yea i got the dreaded sticky pedal. on hard shifting from second to third it would go to neutral and wouldnt move past. my pedal would engage at the floor and makes you loose races.... so i pulled the spring and now the pedal comes back everytime. its only a temporary fix to my problem but the clutch pedal feels so much better and isnt really much stiffer. in fact i bet you wont notice the difference in 2 days of driving.
Old Aug 29, 2005 | 10:11 PM
roSSco's Avatar
roSSco
Old Aug 29, 2005 | 10:18 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Mine broke driving easy a year or so ago, I just took it out and it solved my slightly stickey clutch issues.
Old Aug 30, 2005 | 12:14 AM
MOL's Avatar
MOL
Sticky pedal: does it mean that it was stuck all the way in?
It happened to me and I couldn't move the gear shifter while it was stuck. I restarted the car, and everything was fine.
My dealer told me that the "slave cylinder" for the clutch was leaking. I haven't gotten it fixed yet, but it hasn't occured since. I don't really think that he knows what the problem is...
Could anyone tell me something about this?
Old Aug 30, 2005 | 12:23 AM
Chris.Shea's Avatar
Chris.Shea
yea air gets into the line and then you get a pedal stuck to the floor. there is a tsb for the problem pi00206. do a search and you will pull up more threads than you know what to do with.
Old Aug 30, 2005 | 12:36 AM
MOL's Avatar
MOL
hmm, so it could be a problem with the slave cylinder...
Should I change the hydraulic fluid regularly?
Thanks!
Old Aug 30, 2005 | 03:08 AM
Chris.Shea's Avatar
Chris.Shea
Thanks!
the fluid turns color because of the black rubber piece on the reservoir... id assume it would be best to flush it to remove the air bubble but the problem will be reoccurant as you havnt removed the problem. i think going to aftermarket solves the problem. something like like a small plastic pieve gets hot and moves to allow air to get into your line and then the pedal turns all spongy and eventually stays on the floor. my grab point goes from close to very top to the very bottom of the pedals travel. the clutch is still holding strong so its a hydrolics problem. mine starts to happen fast now... it hints its going to happen on my 2-3 shift and then it comes up very slow on my 3-4 shift while im going down the strip. i still havnt taken it to get serviced but i just moved here to maui and we only have one gm dealer
Old Aug 30, 2005 | 07:19 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
I removed mine. It helpedmy sticky pedal problem... but now its back again after a power upgrade
steve
Old Sep 9, 2005 | 01:12 AM
Fusion_Z06's Avatar
Fusion_Z06
5th Gear
Funny I fould this post some people have told me that i need that spring to pull the pedal back up! I'm going to try that first thing tomorrow
Old Sep 9, 2005 | 10:09 AM
t56gen3's Avatar
t56gen3
Yep there is a misconception that it's a return-spring, but it's there to reduce pedal effort to make it more comfortable to drive.
To busted clutch pedal spring !
