need advise on tires
Old Aug 29, 2005 | 12:46 PM
Dmanf's Avatar
Dmanf
Cruising
Default need advise on tires
After only being lit up once and after a mear 13,000 miles my Goodyear Eagle F1 GS EMT's are down to the wear bars and beyond (on the rears front still have tread).Anyone with recommendations on a good replacement tire that gets better mileage and still has good performance. otherwise its $850 a set a year ouch!!
Old Aug 29, 2005 | 12:50 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Where do you find a set of Vette tires for $850? ...unless they are non-runflats...
Old Aug 29, 2005 | 12:56 PM
Dmanf's Avatar
Dmanf
Cruising
Set as in two..Goodyear quoted me $425 per without mounting and balancing
Old Aug 29, 2005 | 01:00 PM
97Black's Avatar
97Black
I recently bought the Kumho Ecsta ASX from tire rack. $540 shipped to me. I don't race or do track but these are a huge upgrade over the GY. They are so much smoother and quieter and should last a long time. I bought a flat kit from tire rack just in case.
Old Aug 29, 2005 | 01:32 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
My EMTs have 16K and still look great.
Old Aug 29, 2005 | 02:33 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
when its time (few months) i will be purchasing a set (4) of BFgoodrich g-force KDW-2. they look great! my friend steve (fixedroof) have been running these tires for a while now. he is very pleased. beats the crap out of them, and still showing no signs of tread wear.
check them out, they have a great tread rating, supposed to perform well, and also on the cheaper side compared to other tires.
in feb. i went with kumho mx's all around. the rears are already worn out pretty bad. they were cheap, but i need something that is going to last a little longer!
Old Aug 29, 2005 | 04:28 PM
STEEL's Avatar
STEEL
goodyear f1 supercar tires are night and day compared to the runflats, they stick very well and tread life is pretty good too.
Old Aug 29, 2005 | 04:29 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Something isn't right to only get 13K out of those tires............
Old Aug 29, 2005 | 04:30 PM
jrose7004's Avatar
jrose7004
Z rated tires aren't known for their mileage!
Old Aug 29, 2005 | 05:47 PM
SLPRC5's Avatar
SLPRC5
..I went from my road noise BG Goodrich T/A non-runflats to Kumhos and they are great for the same reasons stated above.
Rsty
Old Aug 29, 2005 | 05:49 PM
ebubman's Avatar
ebubman
concur with the others---consider using www.tirerack.com. there are many, many, many satisfied customers here on the forums. bub
Old Aug 29, 2005 | 06:31 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Another tire you might check out is the Goodyear GS-D3 non-runflat. I've read many many good reviews on these. My original Goodyear runflats have almost 16,000 on them with the fronts having a little more tread than the rear. I will be going with the GS-D3's before long.
To need advise on tires
