Cags skip shift not working anymore
Old Aug 30, 2005 | 11:53 AM
WaWaTuSi's Avatar
WaWaTuSi
St. Jude Donor '05
Default Cags skip shift not working anymore
Gentlemen,
I have installed now 2 Cags skip shift eliminator things.... Both worked for a few months but now the Check engine light comes on constantly (though the skip shift feature still works.)
Any Ideas?
Thanks!
Note to red97vette
I have the info you need but your mailbox is full!
Old Aug 30, 2005 | 12:28 PM
CUlookin's Avatar
CUlookin
Are you sure your check engine light is related to the CAGS eliminator? what code triggered the light?
Old Aug 30, 2005 | 02:03 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Aug 30, 2005 | 02:29 PM
DngrZne's Avatar
DngrZne
Any corrosion on the connectors possibly allowing the computer to see that the CAGS system is unplugged?
Old Aug 30, 2005 | 03:01 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
These are the FIRST two questions you must ask yourself.
Do that, answer them, then get back to the forum.
Larry
code5coupe
Old Aug 30, 2005 | 09:12 PM
WaWaTuSi's Avatar
WaWaTuSi
St. Jude Donor '05
No corrosion. Checked after I installed the second one.
If I put it all back stock. No check engine light.
Code is:
P0803
1-4 Upshift Solenoid Control Circuit (M/T)
Old Aug 30, 2005 | 11:53 PM
I can't recall seeing another post where the CAGS eliminator caused any problems. Mine has now been on two different cars and no issues. If you are able to track down the source of your warning light, let us know what you find out.
Old Sep 1, 2005 | 12:06 PM
WaWaTuSi's Avatar
WaWaTuSi
St. Jude Donor '05
Will do
Old Sep 1, 2005 | 02:51 PM
2KFRC5's Avatar
2KFRC5
I don't have one, but can you put an ohmmeter across the bypass to see if it is good or not. And can you get to the resistor to replace it, if necessary? Just a thought.
Old Sep 1, 2005 | 03:08 PM
2KFRC5's Avatar
2KFRC5
I'm reading that the bypasses quit working. Right? An open circuit giving the code? Back to stock = normal.
Old Sep 1, 2005 | 05:59 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
I'm guessing the resistor went bad for some reason... a few cents at Radio Shack should solve it.
Old Sep 1, 2005 | 06:03 PM
matt24's Avatar
matt24
Sounds like its bad but using skip shift right now isnt a bad idea!
Old Sep 1, 2005 | 06:16 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
I'm thinking about getting one, but I have only it it on e time since I bought the car last Oct. Maybe it's just me but I never shift it that low???
Peace
Willfulone
__________________
..................Click for
To Cags skip shift not working anymore
