I hit 234 yesterday.
Old Aug 30, 2005 | 03:50 PM
IDRVFST's Avatar
IDRVFST
From: South Coast Metro, CA (It sounds better than saying, "Santa Ana")
Default I hit 234 yesterday.
Degrees that is.
Air temp was 93º and I was sitting in traffic with the A/C on. It dropped back down when I turned the A/C off but at the same time, the traffic eased up so I don't know how much good turning off the A/C really did.
Questions:
A) Is 234º okay? The manual says the alarm goes off at 255º.
B) Besides driving faster, is there anything I can do to make my engine run cooler?
Old Aug 30, 2005 | 04:00 PM
sgreen4067's Avatar
sgreen4067
234 is fine.. just check for crap between the rad and ac rad. the vette like to suck up everything including small children..
Old Aug 30, 2005 | 04:02 PM
Kanon's Avatar
Kanon
I honestly don't watch mine too closely, so I'm not sure what the normal range is for coolant. The obvious things to do/check are:
1) Make sure you have proper fluid levels and they have been changed according to the recommeded service intervals.
2) Clean the radiator (search for suggestion on how to)
3) Check and make sure your fans (pretty sure this car has two) are working.
Old Aug 30, 2005 | 04:09 PM
norsemn's Avatar
norsemn
For a drastic rememdy, turn your heater on full blast (I know...in the summer that sounds stupid). By turning on the heater, you have increased the area for heat transfer and then the fan increases it further. I have used this in the past. Also, if it is a mechanical fan vs. an electric fan, revving the engine increases the fan speed, thus pulling more air through the radiator. Will NOT work with electric fan.
Old Aug 30, 2005 | 04:10 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
search...
and
have fans reprogrammed and or clean radiator is what you'll find you need to do to bring temps down
Old Aug 30, 2005 | 04:12 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Actually it's better to keep your air on high when your stuck in traffic. At speeds less than 35 mph the a/c will keep your fans on. Your low speed fan comes on at 226 and goes off at 219. High speed fan goes on at 235 and off at 226. I thinks that's right. Somebody will correct me if I'm wrong.
Old Aug 30, 2005 | 04:34 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Get a 160 thermostat!
Old Aug 30, 2005 | 04:41 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Am I totally out to lunch? If the thermostat is completely open (which it certainly would be if the coolant temp is 234) how would a 160 degree thermostat help?
Old Aug 30, 2005 | 04:47 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You're right, he is wrong. Thermostat controls min temp, not max
Old Aug 30, 2005 | 05:40 PM
BAMF AE's Avatar
BAMF AE
My bad.... I was doing my usual speed-reading and completely mis-read the question.... Sorry about my earlier post. I'm in agreement with MY1STPEWTER's post!
Turning off your a/c really doesn't do anything... Remember, the car has two fans beneath your air-bridge.
Old Aug 30, 2005 | 05:44 PM
ebubman's Avatar
ebubman
on hot days, stop & go w/ a/c on, we routinely hit 226 degrees. get moving on an expressway & it drops right down to 196 on the button. bub
Old Aug 30, 2005 | 05:52 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Best thing you can do is clean the accumulated junk out of the A/C condenser and radiator fins. You have to remove the top shroud cover to get to the radiator as it's behind the A/C condenser.
This question is brought up so many time in Summer it ought to be a sticky.
Old Aug 30, 2005 | 06:02 PM
C5 4 ME's Avatar
C5 4 ME
Hey, IDRVFST. I see you have a 98 Vette like mine. You might want to change your Dexcool depending on your miles. I did and it helps with temps. Hope this helps.
Old Aug 30, 2005 | 06:27 PM
hibiscus805's Avatar
hibiscus805
You are right, but.
But, a long time ago I posted a question asking where is and how to remove the top shroud.
I am still waiting for the help of the Forum members.
No rush guys, I am very patient.......and retired. Give the answer to my survivors in case...................it takes time to reply to such a minor issue. And BTW I did not check yet (of course) if the car is a vacuum cleaner but it aspires a lot of chicks.
In the meantime in 94+ temp coolant doe not go over 208 with some peaks at 212-218 and oil reaches a max of 218.
Old Aug 30, 2005 | 07:27 PM
sxeC7's Avatar
sxeC7
Originally Posted by hibiscus805
You are right, but.
OK here's the drill, better late than never. The top shroud is held down by two screws on each side next to the hood supports. You'll have to loosen the airbridge to get it out. After removal, take a hose either water or air to clean the fins on both units. I prefer air, as it's less messy. I put a 18" piece of 3/8" hose on my air gun nozzle with a 1/8" pipe elbow on the end so I could get between the radiator and the A/C condenser. There's only about an inch of space. Got over a cup full of sand , dirt, and general stuff out.
Old Aug 30, 2005 | 08:09 PM
hibiscus805
Thx very much.
I appreciate that you took your time to answer my concern.
Again, thank you very much.
Old Aug 30, 2005 | 08:36 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Try living her in Sin City were temps have hit over 120 degrees this summer....Can't tell you how many time i have reset the fan temps....nothing really helped that much. Hit over 250 once and warning light came on...When temps hit over 240 degrees i just turn the a/c off...
To I hit 234 yesterday.
Old Aug 30, 2005 | 08:42 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
damn thats hot
105 on the DIC and I was still under 200 degrees
Old Aug 30, 2005 | 09:50 PM
TJ Singh's Avatar
TJ Singh
Default I reached 220degree
i have noticed that the temp reached 220degree at idle. even upto 230degree, well I will clean the radiator and air ducts and see what happens.
LATE TJ
Old Aug 30, 2005 | 09:56 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Originally Posted by IDRVFST
Degrees that is.
Questions:
StuzVete was bumping 234 to 240 with A/C
...took and look and my yard was in the radiator...
I mean it looked fuzzy...
Rinsed the dirt and sand and other hairy things out and was amazed that it actually ran across town at 94-97 degrees and then romped on it a little and only made it up to 225...
...it only takes a very little debris to run hotter...
