Cleaning Radiator/AC Condensor
Old Aug 30, 2005 | 06:34 PM
Lestat712's Avatar
Lestat712
Default Cleaning Radiator/AC Condensor
When I was doing my oil change, I tried to clean the radiator off a little. It wasn't too bad, but I figured with all of the experience of the forum members, I thought someone could give a newbie a step by step instruction on how to clean both the radiator and the ac condensor properly, and more importantly, the easiest way. I've done a search, seems alot of people use their air compressor (which I don't have) or take the radiator shroud totally off. Pictures would be great!
Old Aug 30, 2005 | 07:47 PM
BanditDude's Avatar
BanditDude
Old Aug 30, 2005 | 10:27 PM
Lestat712's Avatar
Lestat712
bump
Old Aug 31, 2005 | 12:33 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Mine is apart now...
...but I wont be able to get a pic until tomorrow...
After removing the intake bridge and any other obstructions over the radiator cover...
then remove 4 bolts on either side of the radiator cover...
..actually sometimes putting it back on is the bear...
With the radiator cover removed you can spray water down through the openings and they may be large enough to clean pretty thoroughly...
...This is a quick and easy way to clean the radiator without actually removing the radiator completely...
...Please be careful not to touch the radiator coils...
Our most efficient radiator is also very fragile...
Old Aug 31, 2005 | 07:51 AM
Lestat712's Avatar
Lestat712
Thanks Stu, look forward to any pics you may take.
Old Aug 31, 2005 | 05:33 PM
Lestat712's Avatar
Lestat712
ttt for more replies hopefully
Old Sep 1, 2005 | 12:14 AM
Prosecutor's Avatar
Prosecutor
Old Sep 1, 2005 | 07:33 AM
StuzVette's Avatar
StuzVette
Sorry it took so long!
I dont have a pic of the radiator before cleaning...
...I try to avoid those pics...
After removing the air intake, then cover the throttle body to keep dirt, water, and rodents out...
you can see to the left of the radiator 2 holes where the bolts were...
...2 bolts on either side hold the radiator cover down...
You can see how clean the radiator is...
I use water to clean the all...
The only percaution...dont allow the air or water nozzle or anything else you may use scrape across an coils...
hope this helps...
To Cleaning Radiator/AC Condensor
