Myth Buster. Interesting TPM article
Old Aug 31, 2005 | 11:37 AM
MTurnbo's Avatar
MTurnbo
Default Myth Buster. Interesting TPM article
Ran across this interesting article on "Tire Pressure Monitoring" systems. Here is an piece of it and the link.http://www.findarticles.com/p/articl..._n6075435/pg_4
[QUOTE]On GM's application of this new TPM concept, there is a wireless RF sensor/transmitter unit built into the valve stem of each wheel. It is inserted from the inside of the wheel and retained by a nut torqued to 35 lb.-in. and sealed with a grommet. The pressure sensors each weigh about 1 ounce (28 grams) and will most likely be noticed during wheel balancing. A 3V lithium battery with 10-year design life powers the sensor, but the sensors do not operate continuously. They transmit a pressure signal only once each hour when the vehicle is parked, and they do not operate at all when the vehicle moves below 20 mph. This schedule preserves battery power. The sensors' signal is received by the keyless entry system's radio receiver, which sends tire pressure information to the Body Control Module (BCM) for display on the Driver Information Center (DIC). A warning is sounded automatically if the pressure falls below 24 psi or rises above 39 psi.[UOTE]
Old Aug 31, 2005 | 11:58 AM
Mike Mercury's Avatar
Mike Mercury
link doesn't work for me.
But from what you've posted; this info has been well known (at least here it has). Since I can't link to the complete article, what specific "myth" does this article clear up?
Old Aug 31, 2005 | 12:06 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Old Aug 31, 2005 | 01:28 PM
javamon's Avatar
javamon
Interesting... here's a partial quoute from the referenced link:
On GM vehicles that leave the factory with keyless entry but without TPM sensors inside the wheels, the TPM function is simply not turned on. If wireless TPM sensors are later installed on the wheels, the TPM receiver and the tire pressure display on the DIC can both be activated with the Tech 2 scan tool. The following Tech 2 menu procedure, as described in the GM service update, will activate the TPM receiver:
If they can turn them on after they leave the factory (with the Tech 2 scan tool) can they turn them off with the Tech 2 scan tool. I'm pretty new to the 'vette community but one of my initial impressions is that the whole run-flat capability (tires and sensors) can be one big PITA. I'm definitely going to non-run-flats when the time comes to buy new tires. If the sensors start acting up, it might be a lot less painful to just tuen them off (if in-fact possible)
Old Aug 31, 2005 | 01:36 PM
2kbluestreak's Avatar
2kbluestreak
I've not seen too many complaints about the C5 Tire Pressure Sensors. I think they did not put them on the Z06 because its tires had steel belts that blocked the signal. I like the idea of the TPM's with non-runflats as they can give you an early warning of a slow leak. All my experience with nails and flats has been that they are slow leaks. Getting an advanced warning lets you fill up with air to allow you to get home or drive to a tire store to get it patched.
Old Aug 31, 2005 | 01:52 PM
javamon's Avatar
javamon
I fully agree....but only until the batteries start dying then you replace the batteries (doesn't look easy based on previous posts) or buy replacement sensors. To me they fall into the "bells and whistles" category...don't add much value but become a PITA when they need to be serviced. I've owned a lot of cars in the 36 years I've been driving and I've managed fine without them up 'till now. Just my opinion, but it would be a nice option to be able to turn the receiver off when the sensor batteries go south. Definitely worth some research.
Old Aug 31, 2005 | 02:22 PM
georgec114's Avatar
georgec114
Some more info on TPM.
TPM's are really nothing new to tire monitoring.
They have been used on aircraft forever and more expensive cars
as well. The C5 designers used them because the car was designed
not to have a spare tire. Therefore, they went with run flats.
(Well actually it was, but final decisions went with RF.)
Well with RF tires, a driver would not necessarily know if and when
they got a flat or were in a low inflation situation.
It's a safety issue and not merely "bells & whistles."
A ten year lifespan is pretty good and from what we've seen so far,
it holds up pretty well.
Also, the Z06 was designed without RF for weight savings and
better tire performance. So a TPM was not needed but a tire patch
kit and inflator was.
Many cars now come with TPMs as does my Mazda3.
Anything which provides a driver with information is a good thing.
Old Aug 31, 2005 | 02:38 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Love the TPS sensors.
Old Aug 31, 2005 | 04:46 PM
MTurnbo's Avatar
MTurnbo
It was just a title. But I've heard several variations on how long the batteries last and on how it operates to save battery power so it was nice to clear these things up as well as learning some new things about the TPM system.
Old Aug 31, 2005 | 06:08 PM
Mike Mercury
yes, it's been discussed here in the past . A savy dealer programmer (if there are any ) with a GM Tech Tool 2 can turn this on and off at will.
To Myth Buster. Interesting TPM article
