Quick Connector for Valantine1
Old Aug 31, 2005 | 07:05 PM
Dirty Howie's Avatar
Dirty Howie
Default Quick Connector for Valantine1
Before I order this little gizmo I would just like to make sure no one is having any issues with it and their Valantine radar units.
http://mysite.verizon.net/ccm.gerber/quickconnect.htm
Anyone do this and then later do a hard wire install for some reason?
And what length should I get? They have 6, 8 and 12 inch lengths.
(My wife says to get the 12" cause thats what she's used to )
DH
Old Aug 31, 2005 | 07:41 PM
steve8's Avatar
steve8
Maybe in your wifes dreams, but that's a different story.
I have this setup with the bracket from great lakes trophy for what I think is great way to go for my V1. The short wire should do fine.
Old Aug 31, 2005 | 07:43 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
You forgot she is use to needing batteries for that too!!
Old Aug 31, 2005 | 07:52 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Yup, works great. The only issue I had was getting the connector out of the mirror. Needed to use some pliers on the tab and rock it back and forth to dislodge it. You might be able to connect the wire without pulling the connector.
Old Aug 31, 2005 | 07:54 PM
LoneStarFRC's Avatar
LoneStarFRC
In the process of installing and removing your V1 (for storage), you must depress the little plastic tab. Do this enough times and, trust me, it will eventually break off. Then you need to go to Radio Shack and get a box of replacement connectors and also the crimping tool used for these style connectors and crimp on a new connector. Problem is, you have to cut off the old connector first. See where I'm going on this? If you use this type set-up, get one long enough for you to be able to replace two or three connectors, because eventually the cord is no longer long enough to reach your V1. HTH
Old Aug 31, 2005 | 10:22 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I've had mine close to a year with no problems. It's just a phone wire for cryin out loud. How could you have a problem with it? LOL
jeff
PS, now watch, the little plastic tab will break off mine tomorrow.
Old Aug 31, 2005 | 11:12 PM
Dirty Howie
Think I will get the 8" wire. Makes sense just incase my tabs break...although I don't plan on removing it very often.
(my wife will just have to deal with the short comming)
Whats this bracket from GreatLakes????
Doesn't the V1 use suction cups to the windshield
Excuse my ignorance...this will be my first ever detector!!!!!!
DH
Old Sep 1, 2005 | 02:26 PM
steve8's Avatar
steve8
DH
Check out Greatlakestrophy.com for a bracket that attaches directly to the mirror. My V1 is hardly noticable this way.
Old Sep 1, 2005 | 07:47 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Howie, Howie, Howie, you walked right into that one.
Good luck with the V1, no guarantee for not getting popped but much better than not having one.
Old Sep 1, 2005 | 10:18 PM
LoneStarFRC
jeff
The Curse of Murphy's Law will now smite thee!!
Old Sep 1, 2005 | 10:25 PM
not08crmanymore's Avatar
not08crmanymore
Default this thing
so this item plugs into the back of the rearview without taking anything apart??and then,no more pluggy into lighter?? thanks.
Old Sep 1, 2005 | 10:29 PM
LoneStarFRC
Yep. That's the idea.
Old Sep 1, 2005 | 10:32 PM
not08crmanymore
Default ok
i'll be buying one then!thanks.
Old Sep 1, 2005 | 10:42 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Me too - except that I just ran an 8' RJ11 cord through the header above the windshield, down the passenger side A pillar, behind the dash and into the footwell fuseblock. I chose an "ignition hot" wire to connect to with the supplied connectors and plugged it in. Pretty simple. And - most importantly, the V1 is always on when the ignition is on - off when it's not........
Oh yeah, and the 12" deal...that might be true if you measure the same way you measure a dog's tail if you know what I mean!
Old Sep 1, 2005 | 10:47 PM
TeamSpeed's Avatar
TeamSpeed
Howie and Jesse, thank you for the order, your cords are going out tomorrow.
Thanks for all the references, folks!
Old Sep 1, 2005 | 10:50 PM
not08crmanymore
Default cord
i just sent a paypal for it.i hope it's as easy to put in as the directions make it out to be!i'm just getting into trying this stuff(installs,etc)on my own.
Old Sep 2, 2005 | 01:33 AM
Dirty Howie
Your welcome.....
Ordered the V1 yesterday
Today.... the QuickDisconnect cord and GreatLakes mirror mount.
Just waitin on the Brown truck......
DH
To Quick Connector for Valantine1
Old Sep 2, 2005 | 03:22 AM
cmeflyby's Avatar
cmeflyby
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
i had never seen this product before. very . even though i like the smart plug on the X50 it will be great to get rid of the dangling cord.
just ordered mine
Old Sep 2, 2005 | 07:57 AM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
DH
I needed the 8" length because I used the visor clip mount from GreatLakesTrophy instead of the under mirror mount. Works great!
**edit**
BTW I ordered both the 6" and 8" lengths and only used the 8" so I have a 6" if anyone wants it.
Old Sep 2, 2005 | 08:11 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
I think that it is just as easy to hardwire the V1 and leave the mirror connections alone.... You are only looking at a 30 minute install....
