Another gauge bezel install <pics>
I had the indicated tools also...and the time (took the day off).
So, I decided to give it a shot.
After several hours, I was more than satisfied with the bezels.
They even match the shift **** and ebrake.
What do you guys think?
they really look kick *** though.. at night they refract light from the gauges and look like a cd's surface as people look in.
Tom
Chevrolet must agree - have you seen the instrument panel on the C6?
Wow, you have done a fabulous job tackling this mod. The custom gauge rings look absolutely great. And, the pic of your car is beautiful. Thanks for sharing.
Best Wishes,
Eden
Though I wouldn't go around scaring everyone else un-necessarily.
I know the properties you speak of: "the metal expands different then the plastic", but at least for me I haven't seen it result in them popping off,
I think the biggest mistake people make is not trial fitting the pieces first. As received, they may not exactly fit the raised circular plastic portion of the factory gauges ... instead needing to have their circumference expanded or compressed a little (talking about the 4 pieces that have notches cut out of their circumference).
If you don't correct this, the glue contact area becomes spotty. The greater the contact area, the better the glue will hold.
But anyways, I find your idea of using silicone adhesive a brilliant idea - as with that substance the contact area becomes less critical.
