Who actually has this mod?
Old Sep 4, 2005 | 10:41 AM
rkhegler's Avatar
rkhegler
Default Who actually has this mod?
I am ordering the under hood stainless steel mirrors from American Car Craft. Does anyone out there actually have this mod? I have seen several posted pictures. I would like some input BEFORE I make the investment. What are the problems with the install? How easy is it to keep clean? Does the engine heat have an adverse affect?
http://www.americancarcraft.com/corv...s/c520alt2.jpg
I am ordering this soon so information is rather important. Can you help me out? Thanks!
Old Sep 4, 2005 | 12:25 PM
C5XTASY's Avatar
C5XTASY
I think it looks very cool, but I wouldn't do it on mine. The reason being, as I have longtube headers, it gets hot enough under the hood without the radiant heat reflective qualities of a mirrired surface back onto the engine. I would think, but may be wrong, that it may tend to prematurely age your wiring insulation. Maybe, if it's not a daily driver, it may not make much difference.
Ed
BTW: How do I get to that part of their website that offers this kit? I tried variations of your picture address with no luck. Thanks!
Ed
Old Sep 4, 2005 | 12:29 PM
hilton head 50th's Avatar
hilton head 50th
Impossible to keep clean without scratching.
Old Sep 4, 2005 | 12:34 PM
QuikZilver's Avatar
QuikZilver
http://www.americancarcraft.com/corvette.html
Old Sep 4, 2005 | 04:58 PM
C6 NOIR's Avatar
C6 NOIR
St. Jude Donor '03-'06-'07-'08-'09
i threw a bunch of under-the-hood ss away in the trash just for that reason
Old Sep 4, 2005 | 05:30 PM
edensknight's Avatar
edensknight
Hi RK,
Regrettably, I agree with our fellow members who have thoughtfully responded to this thread. Last year, I purchased some of the very attractive and highly polished SS underhood treatments for my C5.
Well, I was not pleased when they came out of the box with excessive glue and fingerprints on the back of the panels with loose rubber molding edges. Moreover, I found that were far too easily scratched with gentle wiping and waxing, let alone from just mere light dust and dirt.
Best Wishes,
Eden
Old Sep 4, 2005 | 06:01 PM
b98's Avatar
b98
Can you tell me how it would increase the temp. just because it is shinney. If you apply 50 deg. to a peace of metal it will not get hotter than 50deg. It must have fuel properties in order to increase the temp. ?????? I could be wrong, but that only happens only once a year.
Old Sep 4, 2005 | 08:22 PM
CUlookin's Avatar
CUlookin
I seen it
Old Sep 4, 2005 | 08:31 PM
Gray Fox's Avatar
Gray Fox
CI 5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08-'09
It looks to busy to me.
Old Sep 4, 2005 | 08:35 PM
tiojames's Avatar
tiojames
Default SS under hood
C5extasy didn't say it would increase the temperature. He said it would reflect the heat back to the engine which it would. One reason they put the dark insulation under the hood is to soak up the heat, not to reflect it.
Old Sep 4, 2005 | 08:56 PM
doug doo wop's Avatar
doug doo wop
I was interested in this but thought it might get scratched easily. Also, is your underside of the hood painted as nice as the outside? Mine isn't and I don't think that would look good. I've replaced that insert in the upper right corner of the hood many times because it scratches so easily. I would think twice about buying this product even though it would look Good luck!
Old Sep 4, 2005 | 09:45 PM
vettes4fun's Avatar
vettes4fun
Old Sep 4, 2005 | 10:26 PM
rkhegler's Avatar
rkhegler
Originally Posted by vettes4fun
Thank you all for your advice. I will reconsider this mod. I will look at some other options. Again Thanks for taking the time.
Old Sep 4, 2005 | 11:01 PM
Prosecutor's Avatar
Prosecutor
Can you please explain how the color of the underhood insulation makes any difference? I am curious. It seems that the composition and structure of the insulation are what is important.
I know that dark colors absorb more light, therefore heat, than lighter shades, but none of that is an issue under the hood where there is no light. Further, I understand that some materials will reflect heat (not just light, but heat) while others tend to diffuse it much more effectively. When you talked about using dark colored insulation under the hood...I am not sure how it makes any difference. It seems that any underhood insulation which has identical composition and structure should be equally effective, regardless of color. Then again, I am not an engineer or scientist, etc...
Thanks.
Old Sep 5, 2005 | 09:49 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I just wanted to order just the chrome caps you know for the washer unit and the oil filler cap ,the power steering unit i should have no problems with buying those i dont want to spend the money to replace all the other things in the engine i did that a along time ago on my 75 vette that was when all the chrome parts were alot cheaper.Do all these caps last for a good long time?I also redid the retainers that hold the hoodliner on with the instructions from one of the forum members awhile back making them look like chrome now.I sure learn alot of good things from the forum members.
Old Sep 5, 2005 | 11:10 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I dont have it and I wouldnt buy it...
VR
Old Sep 5, 2005 | 10:06 PM
doug doo wop
Never had any problems with the chrome caps, try "corvette engine covers" caps. The hoodliner retainers is a nice touch and should last forever; cheapest mod I ever did and looks great.
To Who actually has this mod?
Old Sep 5, 2005 | 11:17 PM
rkhegler's Avatar
rkhegler
Where did you get the hood liner retainers?
Old Sep 5, 2005 | 11:36 PM
bobdt173's Avatar
bobdt173
Cruise-In VII Veteran
I have some ss pieces made by kirban I think. They are scratched up like everyone else has said. I am going to eventually convert my ss pieces to chrome by http://www.creativeenginecovers.com/c5chrome1.html from what I have seen chrome will not scratch as bad as ss. You might want to save for a while and get the good stuff if you are serious about showing your car.
Just a suggestion,
Bob
Old Sep 6, 2005 | 12:07 AM
rkhegler's Avatar
rkhegler
Just a suggestion,
Bob
I have much of what is pictured on the web sight. I just wanted to jazz up the underside of the hood. I am going to go to a plating place tomorrow and see what they charge to Chrome the pieces if I manufactue them.
