What gear for DYNO Pull
Old Sep 5, 2005 | 07:29 PM
Jserman's Avatar
Jserman
Default What gear for DYNO Pull
I know when I had my 3.42 I did my dyno pulls in 4th...
Now I have 4.10s so I was wondering do I do my pulls in 5th now?????
Old Sep 5, 2005 | 07:45 PM
T_Vert's Avatar
T_Vert
still 4th, its a 1:1 ratio in trans. But the gears will skew hp/torque some. id like to know your before and after 4.10 dyno results.
Dave
Old Sep 5, 2005 | 08:00 PM
Jserman's Avatar
Jserman
well I just put a procharger on so my reading will be alot higher..
but yea I wish I would have dyno'd it after the 4.10 install..
So will the numbers read higher or lower?????
Old Sep 5, 2005 | 09:07 PM
joseph796's Avatar
joseph796
The higher gear, the lower the dyno results will read. For example, the same vehicle will have lower hp/torque figures with a 4.10 gear than a with a 3.42, but on the road, the 4.10 will be quicker.
Old Sep 5, 2005 | 09:17 PM
WEF's 95's Avatar
WEF's 95
How can gears affect horsepower? I can see it moving the power to different speeds but it should remain the same at rpm's before and after gear change. A higher gear may not let you attain the peak power.
Old Sep 6, 2005 | 12:30 AM
Dyno Dan's Avatar
Dyno Dan
Basicly you need to find out where 1:1 is. An example might look like this:
Final Drive: 3.42:1
GEAR RATIO
1 2.66
2 1.78
3 1.30
4 1.00 ***
5 0.74
6 0.50
To What gear for DYNO Pull
