visor replacement
Old Sep 6, 2005 | 01:18 PM
jdee702's Avatar
jdee702
Default visor replacement
I was wondering if anyone had guidence/experience replacing a "sunshade" visor on a convertable. It looks simple enough, but I would hate to jack it up. That has been my luck lately.
Old Sep 6, 2005 | 01:31 PM
LV_2_XLR8's Avatar
LV_2_XLR8
It's easy. All you have to do is put a screwdriver blade in the slot in the plastic where the visor mounts to the header. With the blade in the slot, swing the visor toward the side window, which will cause the plastic base to turn. The visor will drop into your hand.
Old Sep 6, 2005 | 01:43 PM
MattB's Avatar
MattB
Yep, just put a flat head in it and turn. Its very easy, and it goes in just as easy.
Where is a good place to get replacements? My drivers side broke.
Old Sep 6, 2005 | 01:51 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Check out this link. Has pics, but like others mentioned, it's pretty easy. I got my replacement from the dealer, before I knew about gmpartsdirect.com. You might want to check them out first.
https://www.corvetteforum.com/techti...D=80&TopicID=1
Old Sep 6, 2005 | 02:06 PM
jdee702's Avatar
jdee702
Thanks fellas!!
I got my visor at the dealership here in vegas. I suppose it would be about the same where ever you go. Mine was $86, A LOT cheaper that I thought it would be.
Old Sep 6, 2005 | 02:10 PM
CUlookin's Avatar
CUlookin
I've tried this and all it did was start to break the plastic ring... Am I doing something wrong here or is mine just stuck?
Old Sep 7, 2005 | 11:45 AM
G-lock's Avatar
G-lock
I wish it were really that simple, my theory is some of the visor mounts are incorrectly assembled at the factory and the only way to get them out is to break them. I say this as I made a Homelink visor for my 99 and I destroyed the inner bezel which is only available on a new visor. Now that I have correctly assembled the new visor it goes in and out very easily, but there was no way the old one would come out with destroying the bezels. As always YMMV. Jeff
To visor replacement
