Cd changer install help!!!!!!!!!!
Old Sep 6, 2005 | 03:00 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Cd changer install help!!!!!!!!!!
My car did not come with the factory changer. I am adding it
The harness??? Does it hook to the back of the radio? or somewhere else? It has two plugs on one end and 1 fat one on the other.
Old Sep 6, 2005 | 03:28 PM
fdxpilot's Avatar
fdxpilot
If your Head-Unit is CD capable, there should be two plugs below the fuse bax in the pass footwell. See this link for more info:
http://forums.corvetteforum.com/revi...7&cat=4&page=1
Old Sep 6, 2005 | 03:36 PM
screw991le's Avatar
screw991le
That has no pictues
Old Sep 6, 2005 | 03:37 PM
reed39's Avatar
reed39
Default Cd changer hook up
CD Changer cable: At the lower right hand corner of the fuse panel area, you should see a plug that looks like one of the two plugs on the CD Changer cable . Taped to that wire or taped right near it is another plug that looks like the second plug on the cable. Cut the tape and plug both harnesses into the CD Changer harness.The wire are difficult to find at times. Route CD Changer harness under carpet at passenger side foot well (I used a zigzag pattern so it laid flat under the carpet. Leave enough to bring wire harness up passenger side kick panel.The 9 pin wire plugs into the CD changer.
Old Sep 6, 2005 | 04:08 PM
screw991le's Avatar
screw991le
Thanks, It is tucked under the rug
To Cd changer install help!!!!!!!!!!
