driver side window loose and rattles
Old Sep 9, 2005 | 06:45 PM
harley76shovel's Avatar
harley76shovel
Default driver side window loose and rattles
Can anyone tell me how to tighten the driver side window on a 98'?
Old Sep 9, 2005 | 07:10 PM
YO-EL's Avatar
YO-EL
the entire actuator & its assy (one entire unit), must be replaced...
There is a bolt at the bottom that mushrooms out.
There is a new design as a replacement with a washer so it won't happen again.
Took my dealer tech about 1 hr to do it yesterday..
Without the repair, your window will rattle & shake in the down position, but will still go up & down no problem.
Until you get it fixed, don't lower the glass 100% all the way down.
Old Sep 20, 2005 | 05:02 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Is there a TSB on this issue? I have an aftermarket bumper to bumper on my car and would like to have the info handy!!
Old Sep 20, 2005 | 07:07 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
I'd also like to know this. Mine rattles like crazy!
Old Nov 28, 2005 | 02:40 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
A couple weeks ago, my passenger window was stuck. After shutting the door a few times, it started working again (tip from the forum). Now the window is starting to rattle at around 45 mph. When I get above 70, there is excessive wind noise. I wonder how much this will cost to repair at the stealership!
To driver side window loose and rattles
