[Z06] Anyone using the "Predator"?
Old Sep 12, 2005 | 06:09 AM
Turbooo2u's Avatar
Turbooo2u
Default Anyone using the "Predator"?
I have a "Predator" tune I recently pulled out of my 99' coupe and was wondering, if after a reflash, it might be worthwhile to install it in my new Z?
Old Sep 12, 2005 | 09:07 AM
barondw's Avatar
barondw
I thought it was married to a single car and not transferable?
Old Sep 12, 2005 | 09:40 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
No.
If this was even possible to do I doubt a tune for a '99 LS1 would run anywhere near as good as the stock LS6 tune on your Z06.
Old Sep 12, 2005 | 12:22 PM
zulatr's Avatar
zulatr
If you reinstall the Predator tune into the machine, and return it to the manufacturer they will update it for you for a fee. You don't want to/can't install the 99 program into your 04.
I know a lot of people on this forum think the Predator isn't worth 2 cents. I got one with my car and it does feel different when I reinstall the stock tune. I've never done any dyno runs or 1/4 mile times to quantify the change. For the $75 or so they charge, it's probably worth it just to have the ability to play with tune to some extent and reset fan temps etc. $400 for a new one, I'd get the car done right with LS1 edit on the dyno.
Old Sep 12, 2005 | 12:30 PM
QuikZilver's Avatar
QuikZilver
I bought one for two reasons:
1. Eliminate CAGS
2. Diagnostics Tool
Actually, I bought it for #2, but the feature to kills CAGS was very nice (no getting under the Vette, just select to not use it and no more light or skip shift). I have their tune on my 01 Z and it did help out a little (SOTP test, no formal test). Once I get headers and other go-fast stuff on...then it is going in for a proper tune.
Old Sep 13, 2005 | 10:10 AM
sshaddowz's Avatar
sshaddowz
St. Jude Donor '05
Also something else to check into, I believe that the predator that you have only works up to 03, for the 04's you have to buy a different programmer from diablo. So the programmer you have will not work on the 04 Z. Bryan
Old Sep 13, 2005 | 10:23 AM
RPOZ16's Avatar
RPOZ16
There are different units for 99-03 years and 04.
To Anyone using the "Predator"?
