Transgo Shift Kit
Old Sep 12, 2005 | 04:37 PM
LaXer6188's Avatar
LaXer6188
8th Gear
Default Transgo Shift Kit
What exactly is a Transgo shift kit and what does it do?
Old Dec 25, 2010 | 10:41 AM
corvettecrazy2's Avatar
corvettecrazy2
Ttt
Old Dec 25, 2010 | 02:18 PM
MNR's Avatar
MNR
Subscribed
Merry Christmas!!
Old Dec 25, 2010 | 08:04 PM
lil vette's Avatar
lil vette
A stock transmission will gradually (slip) go into gear to give driver a feel of smoothness. This is done by causeing the clutch pack to slip ever so slightly during gear change. A shift kit will increase fluid pressure, useing tiny ballls & springs. This stops the slight slipage & will thrust driver into seat at shift points. Clutch pack will last longer because now there is no slipage.
Old Dec 25, 2010 | 09:31 PM
soggysailor's Avatar
soggysailor
BUT........ won't a tune be able to accomplish the same thing and more?
Old Dec 26, 2010 | 10:44 PM
MNR's Avatar
MNR
My assumption is that with the tuner, you are telling the [plastic] clutch packs to increase pressure - causing for a ''firmer'' shift. The transgo kit on the other hand, increases pressure by installing different parts which directly allows for "firmer" shifts.
I am not by any means a mechanic, but thats just my 2 cents. I would love to hear a correct answer if anyone knows though!!
Old Dec 27, 2010 | 05:28 PM
lil vette's Avatar
lil vette
After installing a shift kit, you still need to go to a tuner to adjust the tables. (firmness & shift time)
Without a shift kit tuner can adjust tables, you will get:
tuner only no shift kit, you will say mmmm that's pretty good. I'm glad i did that.
With a shift kit, after tuner you will say, HOLY ****!!!!!!!!!!!!!!!!!!
SOMEBODY STOPME.
by law, you must get neck injury insurance for passenger, hehehehee
To Transgo Shift Kit
