amsoil
Old Sep 13, 2005 | 09:23 PM
bowtiebubba's Avatar
bowtiebubba
Default amsoil
I am going to change out the transmission (mn6) and differential fluids. I need to know what amsoil products to use? Do ant of the major auto stores sell amsoil? Thanks Guys
Old Sep 14, 2005 | 12:51 AM
Vette5.5's Avatar
Vette5.5
Here in MI, Murrays auto parts sells Amsoil. Don't know what you've got in MO. If I were changing out the fluid in my MN6, probably go with Red Line or Royal Purple synthetics. Heard these products really smooth out the shifting of the MN6. Surely some forum venders sell these products as well as Amsoil. Locally, you're speed shop is the best bet. Just make sure you bring enough money.
Old Sep 18, 2005 | 03:02 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Bowtiebubba,
Appreciate your consideration of AMSOIL and sorry I missed this first time around. I am a forum vendor and all sales of AMSOIL via my dealership benefit the forum and my raceteam. Ordering info for AMSOIL via my dealership (which does include the banner link to the left) can be found via the link in my sig.
AMSOIL products I recommend for the C5/Z06 (All meet GM specifications):
Engine oil:
High Performance
AMSOIL Series 2000 0w30
Daily Drivers
AMSOIL SAE Synthetic 5w30
Oil Filter (part SDF32):
AMSOIL SDF Oil Filter
Transmission Fluid (meets GM Dexron III requirements for both A4 and MN6/12):
AMSOIL ATF
Gear Lube:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
Preferred Customers order at wholesale:
AMSOIL Preferred Customer Program
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 25, 2005 | 10:00 AM
YO-EL's Avatar
YO-EL
What series for cars that are drag raced often & also driven?
Old Nov 25, 2005 | 01:25 PM
C66 Racing's Avatar
C66 Racing
What weight oil do you run in your car now?
Is it under warranty?
If your car is under warranty, I would recommend, in this order, these AMSOIL products which meet the GM Standard 4718M for your engine:
AMSOIL SAE Synthetic 10w30
If your car isn't under warranty, and depending on what viscosity you currently run, I'd consider these oils which do not meet GM Standard 4718M but do meet API SL standards:
AMSOIL Synthetic 5w40 European Motor Oil
AMSOIL SAE Synthetic High Performance 10w40
For the tranny:
AMSOIL ATF
For the diff:
P.S. Dropped you a PM with info on the AMSOIL Preferred Customer Program
Old Nov 25, 2005 | 02:35 PM
YO-EL's Avatar
YO-EL
Using this :
To amsoil
