Am I getting ripped off?
Old Sep 14, 2005 | 04:31 PM
DoomDRV's Avatar
DoomDRV
Default Am I getting ripped off?
My headlights - after they close - not when you open them - emit a loud burrrring noise. Dealer says I need a new motor - $450 Can with tax and labor
Does that sound right or could they replace the gear drive which I believe is plastic only??
All help appreciated
Old Sep 14, 2005 | 04:36 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You don't need the whole motor - you need to replace a worn out plastic gear with the brass ones that are available.
http://forums.corvetteforum.com/showthread.php?t=711276
http://www.rodneydickman.com/retail.html
Old Sep 14, 2005 | 04:47 PM
Dyno Dan's Avatar
Dyno Dan
Once again the STEALERSHIPS cant seem to do right by the customer. What ever happened to an informed and honest service writer/manager?
Old Sep 14, 2005 | 08:00 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is a simple DYI. $450
Old Sep 14, 2005 | 08:32 PM
bigsal01's Avatar
bigsal01
most dealers on parts suck big time good thing for dealers like fred bean
Old Sep 14, 2005 | 08:54 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
DIY and save around $400.
http://my.execpc.com/C4/4A/rodney1/vettegears/
Old Sep 14, 2005 | 08:58 PM
cortex's Avatar
cortex
Originally Posted by Mike98SilVert
Actually, it can be a free fix if you want. Follow these instructions but just flip the existing plastic gear over. Only half the gear is used so the other part of the gear is just fine. Did this two years ago after experiencing the problem and still works fine...
Old Sep 14, 2005 | 09:02 PM
edensknight's Avatar
edensknight
Another vote for the DIY and the brass gears.
Old Sep 14, 2005 | 09:06 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Exactly what I would do!
Old Sep 14, 2005 | 09:12 PM
Old Sep 14, 2005 | 09:41 PM
diyguy's Avatar
diyguy
Use the flip it trick, but go ahead an order the replacement gears. Will help to have an assortment of 1/4 drive sockets, extensions and elbow(u-joint) knuckles.
Comes out (with proper tools) in about 5 minutes. 20 minutes or so to clean out the old gear mess and install, reseal the new one.
Can be tricky getting all the bolts and nuts back in (total of 6 - I think)...nice to have a magnet just in case you drop one but it is NOT difficult.
I just did mine about a month ago and was amazed how easy it was.
Old Sep 14, 2005 | 09:45 PM
JWG's Avatar
JWG
St. Jude Donor '07
To Am I getting ripped off?
