From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Originally Posted by Ducman69
Be careful, I've seen some damage done by high temp powder coating ovens. If it doesn't crack the wheel outright, it'll definitely weaken it.
I believe you have to use a special lower-temp technique for wheels.
Most damage is done when the wheels are heated above 500 degrees. So yes, be careful when powder coating. Most powder coating paints usually cure around 400 degrees.
