[Z06] ZO6 Rocker Arm Question...
Old Sep 15, 2005 | 12:21 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default ZO6 Rocker Arm Question...
Curious are the ZO6 rocker arms roller? I don't believe they are, but looking for a solid answer.
Also, the SLP packages they offer, would you replace the rocker arms in the LS6 heads with the SLP pakcgae arms they have? Are they a increase in performance over the LS6 arms?
Just curious and would like to hear your opnions.
Micah
Old Sep 15, 2005 | 02:20 PM
l2vette's Avatar
l2vette
Old Sep 15, 2005 | 02:22 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Just the fulcrum area not at the tips. So they are part roller rockers! Yeah I wonder why GM cheaps out all of the time too?
Old Sep 15, 2005 | 02:25 PM
Michrider's Avatar
Michrider
Stock, they are roller pivot and flat tip. Fine for the stock application. If the whole valvetrain is being upgraded with a higher performance cam, there is a little gain to be had with a full roller rocker which would also have a roller tip. But you would need to be going pretty radical to really see a benefit.
Even the 505 hp new Z has roller pivot and flat tip, and that one revs to 7 grand.
To ZO6 Rocker Arm Question...
