The car still has the original clutch. When I got the car 2 1/2 months ago the vibration wasn't there. I started to notice it after the drivers side output shaft seal and o-ring was replaced recently.
Thanks. I did that this morning and there was no vibration. I can go WOT through the gears and the car is smooth all the way 6500 RPM. It only does it while cruising at 2500 RPM.
I did notice that my pass. rear wheel is missing the stick on balance weights. A couple of weeks ago heard something hit the pass. rear wheel well on the way home and just dismissed it as a pebble that was stuck in the tire.
