what's this code?
Old Sep 17, 2005 | 09:48 AM
slvr bulit's Avatar
slvr bulit
Default what's this code?
98 coupe service car soon light comes on once a month the code is 28 tcs c1281 h. Car runs great
Old Sep 17, 2005 | 10:02 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It is a Steering Sensor error.
C1281 Steering Sensor Uncorrelated Malfunction. The H indicates that it is a history code ( it happened in the past and it is not currently causing a problem) Probably needs to be looked at. I'm hopeful someone with more detail can post in and point you to a fix.
Paul
Old Sep 17, 2005 | 10:38 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
C1281, C1283, or C1286 VSES Sensors Uncorrected
VSES = Vehicle Stability Enhancement System
Could be Yaw Rate sensor...... I've seen this one before
All a part of Active Handling
VSES sensors work by recognizing wheel skid. When you skid, sensors monitor the difference between the steering wheel angle and the direction a driver is actually turning, the vehicle speed, and other factors. After analyzing what's taking place, the system automatically reduces engine torque and applies pressure to the front right or left brakes to help keep the vehicle along its intended path.
To what's this code?
