LS1 engine valve taps !
Old Sep 20, 2005 | 05:14 PM
killain's Avatar
killain
Oldtimer
Default LS1 engine valve taps !
Anyone else out there get a slight valve tap as the engine warms up? I have a 03 50th edition coupe. The dealer said there's nothing they can do about as it's considered to be an operational noise, thus part of the normal operation? It's kinda annoying first thing in the morning.
Old Sep 20, 2005 | 06:38 PM
JCR's Avatar
JCR
Called "Piston Slap" I believe there is a class action suit against GM out there.
Old Sep 20, 2005 | 06:47 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Yeah I noticed a little valve tapping before my h/c install. If I've still got
it I wouldn't know cause the valve train noise would cover it up!
Old Sep 20, 2005 | 06:57 PM
joghotrod's Avatar
joghotrod
I have the valve noise sometimes. I think it is because the oil is still cold and the lifters stick. It goes away when the engine warms up. It is not the piston slap noise. They are a totally different sound. Jimmy
Old Sep 20, 2005 | 07:47 PM
killain's Avatar
killain
Oldtimer
Thanks, I was wondering if I wasn't the only one with the light tapping on start up !
Old Sep 20, 2005 | 09:52 PM
jrose7004's Avatar
jrose7004
I'm lucky mine doesn't do that!
Old Sep 20, 2005 | 10:39 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
www.pistonslap.com
To LS1 engine valve taps !
