Lights Out
Old Sep 21, 2005 | 07:21 PM
redrager's Avatar
redrager
Default Lights Out
I have a 98 Corvette;the problem I have is the under hood light does not work;also the visor vanity lights do not work.Are these two connected somehow? I looked in the owners mannual for the fuse location;could not find one for either.any ideas?
Old Sep 22, 2005 | 06:37 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I'm not sure if the two are connected or not. Have you checked your fuses? The under the hood light could be as simple as the previous owner unplugged it. Did it work before? When I got my '97 my light didn't work. It turns out the previous owner had unplugged it which is fairly common for people that show the car. I plugged it back in and it still didn't work. I had to clean the connector with a small wire brush and some alcohol and that did the trick, it has been fine ever since. It could of course just be the bulb as well. A little more detail maybe?
Paul
