Dyno results from larger MAF?
Aj
Aj
All this depends on how driveable you want the car, and what GM is reflashing your PCM to. I just had experience with this again today. The latest program from GM to address the column lock richens up the car, to the point where mine with the screen in stalled stalled repeatedly at idle when cold, and ran like a pig between 2,500 and 3,500 at wide open throttle. Actually dropped rpm at 2,800 under WOT.
They wouldn't flash me back to the older program (which was fine with the screen in -- I gave up 10 hp for better low- to mid-throttle rpm throttle tip-in), so out of frustration I took out the screen, put the screen-less MAF ends back in, and now the car runs like a champ again.
It's a trail and error thing. You can pick up 10 rwhp, but you need to look at the overall performance and driveablity, and what you are willing to live with on the street.
Oh, BTW -- you can see the driveablility issues in the graph above -- look at the 2,000-2,700 range on the graph.
Hope this helps!
