stiff suspension. what can i do?
Old Oct 1, 2005 | 12:43 AM
saniterium's Avatar
saniterium
Originally Posted by Swany00
sell it and buy a cadillac
Exactly what I was going to suggest.
Old Oct 1, 2005 | 08:15 PM
mse's Avatar
mse
hey, i got rid of the run craps. that made a slight diff, but not as much as i want, so i think i'm going to buy the qa1's. will it really make that much of a difference? i want to absorb the rear impact. i think i'll just do the rears to start.
Old Oct 1, 2005 | 09:14 PM
RonJ's Avatar
RonJ
Originally Posted by mse
which tires would you recommed for high comfort and low road noise? what are the best options? thanks.
In my opinion, the Michelin Pilot Sports are hard to beat. Good tire on a wet road too!!
They are not run flats, get yourself a compressor and plug kit to go with the tires!!!!
Ron ...
Old Oct 1, 2005 | 10:13 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
are the QA1's more confortable than stock for city roads?
Absolutely because you can set them for the desired ride.
Old Oct 1, 2005 | 10:59 PM
mse's Avatar
mse
which one did you get? 'c' series with 12 adjutments? i'm seriously considering these? i'm hoping it'll help a lot on my daily driver. thanks.
Old Oct 10, 2005 | 02:45 AM
mse's Avatar
mse
i put QA1's on the rear. now that the shock sensor is not attached i'm getting a ride control indicator with shock malfunction and cannot go over 80mph. what can i do?
Old Oct 10, 2005 | 02:47 AM
mse's Avatar
mse
i just replaced the rear stock shocks with QA1's. in doing so, the old shocks with the sensor wire had to be removed. now the shock malfunction indicator comes on and i cannot go more than 80MPH. what can i do about this?
Old Oct 10, 2005 | 02:54 AM
skeet's Avatar
skeet
Enjoy it. It's all in your mind.
Old Oct 10, 2005 | 03:09 AM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
You may have better luck posting your question over in the tech section.
I am sure someone will have your answers
