Seat belt
Old Sep 22, 2005 | 12:27 PM
mike348's Avatar
mike348
Default Seat belt
Does anyone have a problem with seat belt locking while you are making a small slow move toward the steering wheel? Is there anyway to stop this?
Old Sep 22, 2005 | 12:41 PM
Mine will occasionally catch at that spot. Haven't figured out a way to prevent it yet.
Old Sep 22, 2005 | 01:31 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Not sure if the "catch" is adjustable or not. If you are moving quickly, I've noticed it does lock up. You may want to post over in the tech section as well to see if it is adjustable.
Old Sep 22, 2005 | 04:21 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Probaly not, my trailblazer does the same thing. I have to come to a full stop and gently pull the belt for some slack.
Old Sep 22, 2005 | 07:18 PM
DngrZne's Avatar
DngrZne
Are you talking about when you are coming to a stop and go to lean forward to look through the intersection? Because in that case it would be the forward momentum of the car causing the belts to lock up automatically assuming you were braking for an obstacle in front of the car.
Old Sep 22, 2005 | 07:59 PM
silverstreak01's Avatar
silverstreak01
it does that for the ones who fall asleep, keeps you off the steering wheel
Old Sep 22, 2005 | 08:59 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
There IS a way to stop it! Stop making small slow moves toward the steering wheel!
Seriously, mine does that, too. Mostly when as stated by someone else, I might be braking, etc. Happens in the parking lot when I'm reaching for my wallet and such.
To Seat belt
