What Length Trailer?
I use a 20' enclosed trailer with a driver's side escape door. Mine was made by Trailerworld in Bowling Green. The trailer has a low profile wheel box so the door will open. I have (and would advise) you to get a "slope nose" trailer, to cut down on wind resistance. I can pull my trailer with my GMC half ton Yukon. Also, I bought my trailer used, it had been used by the NCM to move cars around.Good luck!
1. Using the factory tie down points, you need T hooks to secure the car.
2. Heavy duty straps, crossed at front and rear.
3. Tie down points in the front that prevent the straps from rubbing on the front underside of the nose.
4. Ramp extension may be necessary to load your car, especially if your car is lowered or has a front spoiler (like mine).
5. Spare tire and "trailer buddy", which is a small chock which you can pull the trailer up on, in case of a flat.
6. Electric brakes on trailer, which also requires a small control unit installed in the tow vehicle.
I could probably think of a few more, but these should get you started in the right direction.
Good luck.
Good luck.
I have a Haulmark elite.Local guy has them here for $5700.00 new.
You can get away with a 18' but would not recommend anything smaller than 20'. The recommendation of 24' is a good one in that it gives you more room which you will end up needing for one thing or another. Since you are from Il I would suggest you run over to Elkhard and visit some of the major trailer manufacturers. Just about every manufacturer can put an escape door in any of their trailers. Hope this helps.
