Tire Pressure Sensor Question???
Old Sep 24, 2005 | 04:30 PM
c5 stash's Avatar
c5 stash
7th Gear
Default Tire Pressure Sensor Question???
Purchased chrome Zo-6 wheels from Corvettes of Houston and am having GoodYear F-1's installed next week. I'm debating whether to have tire sensors switched to new wheels. I'f I don't, can the warning indicator be turned off?? I've got a 1999. I've heard that pre 2000, the indicator can't be de-activated, and have to keep resetting dash indicator.
Old Sep 24, 2005 | 04:42 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
No way to turn it off that I know of, other than to hit RESET when you start the car. Question is, why run without the sensors? You can mount them in your new wheels.
Old Sep 24, 2005 | 04:44 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Originally Posted by c5 stash
........................... I've got a 1999. I've heard that pre 2000, the indicator can't be de-activated, and have to keep resetting dash indicator.
I have heard that same thing about the pre 2002.
With the absence of senors in my 2002 the computer would just show the last reading it ever recieved from the sensors when there WERE there last.
Just buy 4 more sensors or swap your existing ones and be done with this problem AND have the added security of the sensors
Old Sep 24, 2005 | 05:34 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You're out of luck. The ability to turn off the sensors came out in 2001 with the Z06 which was the first to eliminate the EMT's. The cars pre 2001 cannot be switched off. If it were me, I'd install the sensors in the new wheels....what can it hurt? I'd rather have the piece of mind.
Paul
Old Sep 25, 2005 | 12:19 AM
No, you can't turn the warning off. I run the sensors in the exact same setup as you are getting and it comes in handy should you start losing air pressure.
Old Sep 25, 2005 | 12:50 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Paul
It was a bit pricey, but I wanted new sensors with my new wheels and tires, so I spent the cash and don't regret it with my non-runflats.
Micah
Old Sep 25, 2005 | 01:52 AM
edensknight's Avatar
edensknight
In the interest of improved tire longevity (especially since tires are so expensive to replace when prematurely worn, leaking, etc.), as well as, assistance in driver maintenance, and, driver safety: Tire sensors are an extraordinary and important driver safety device. These remote sensors made by Schrader in the U.S. have now become o.e. on most American and European automobiles. And, readily alerts the driver to the exact tire afflicted with low air pressure before the issue evolves into a more serious condition such as premature tire wear, tire-belt separation, blowout, etc.. Be Safe.
To Tire Pressure Sensor Question???
