[Z06] Engine light on 04 z
Old Sep 24, 2005 | 09:45 PM
DBOYZ06's Avatar
DBOYZ06
Default Engine light on 04 z
installed vararam, engine light came on after couple hundred miles. I know by getting it tuned will fix the problem. My main concern is that when i went through the codes, other than the two common ones, other codes showed up. Is this normal? Or should no other codes show up?
Old Sep 24, 2005 | 10:16 PM
exracer28's Avatar
exracer28
what were the codes?
Old Sep 24, 2005 | 10:25 PM
Brian Laser S4
Guest
Posts: n/a
My guess without codes, you probably have a leak on the intake install.
Brian
Old Sep 24, 2005 | 10:47 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
'04s are reported to be tuned a little leaner from the factory compared to earler years. This with the fact that a Vararam also leans, leads to codes on '04s more than previous years. Like you said a tune is in order, as Vararam gains are well worth the effort. Other codes, we need the numbers to say what/when/why.
Robert
Old Sep 25, 2005 | 07:39 PM
AZ99FRC's Avatar
AZ99FRC
Robert
Another option is a handheld programer like the Predator or the Vinci. I installed a Vararam on a '04 Z and got codes galore. Bought a Vinci and used their high performance tune. No codes in the six months since.
Old Sep 26, 2005 | 12:32 AM
slong's Avatar
slong
Robert
Well posted
Old Oct 1, 2005 | 09:44 AM
DPG's Avatar
DPG
St. Jude Donor '06
Same here, Just installed the vararam b2 and after about 20 miles or so, I got this code
P0430 TWC System Low Efficiency Bank 2
Would a tune get ride of this and also is this bad to drive on?
Dave
To Engine light on 04 z
