Remove Change Oil Off Dash
Old Sep 25, 2005 | 10:38 AM
BOBBIE's Avatar
BOBBIE
Default Remove Change Oil Off Dash
I Have An 01 And Just Changed Oil How Do I Remove The Change Oil Soon Off The Dash Display
Old Sep 25, 2005 | 10:41 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
with your Key on Engine off, clear the DIC of codes using the reset button, then using the trip button display your oil remaining. Then press and hold your reset button until the % goes away and it's a few ---
It will then reset to 100 when you start your car next.
Chris
Old Sep 25, 2005 | 10:45 AM
Patches's Avatar
Patches
You can also turn the ignition to ON without starting the engine and press the accelerator pedal to the floor three times, turn the ignition switch to OFF and it'll reset the oil life monitor.
Make sure you have your Ruby slippers on and say, "There's no place like home" three times.
( jk on that last part.)
Old Sep 25, 2005 | 10:48 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
they got it
Old Sep 25, 2005 | 11:46 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
This one is the only one that works for my car
Old Sep 25, 2005 | 12:10 PM
LS9's Avatar
LS9
( : jester jk on that last part.)
nuts, I ALWAYS do that
Old Sep 25, 2005 | 03:59 PM
edensknight's Avatar
edensknight
Stangkiller and Patches have saved the day. Gee, I am beginning to wonder about this ruby red slipper fetish.
Old Sep 25, 2005 | 04:20 PM
LS9's Avatar
LS9
it's a Dorothy fetish
Old Sep 25, 2005 | 05:23 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
You had to add the last part didn't you! I was going to sell him a pair of these
http://cgi.ebay.com/NWT-WIZARD-OF-OZ...QQcmdZViewItem
Old Sep 25, 2005 | 05:36 PM
corvetteman39's Avatar
corvetteman39
So is this the same way to do the low washer fluid setting reset too? I had it come on and I topped it off and the warning still comes up.
Old Sep 25, 2005 | 05:53 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Does it still come up after you hit reset?? I know on my truck the warning doesn't come back on after I fill it up.
To Remove Change Oil Off Dash
