checking codes
Old Sep 25, 2005 | 10:30 PM
Snidley's Avatar
Snidley
Default checking codes
I've been told that codes can be checked and cleared through the DIC. If true, how?
Old Sep 26, 2005 | 02:10 AM
GrayC5's Avatar
GrayC5
1981 - 2004 Corvette Computer Codes
Old Sep 26, 2005 | 06:56 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
hold the option button down and press the fuel button 4 times. the DIC will run thru the checks When done, it will go into manual diagnostics, where you can reset the codes with the reset button. when done, use the K/M button to exit. I write down the codes to check to make sure the thing ain't goig to explode or something
To checking codes
