HELP- Removing rear/front letter inserts
Old Sep 26, 2005 | 01:26 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
Default HELP- Removing rear/front letter inserts
Hi!
I am about to remove my raised rear letter inserts and my front decal letter inserts. They are currently red, I am changing to Chrome/Mirror My C5 is Pewter.
Any tips? I have no idea what adhesive was used to put them on. They were on when i bought the car. I do not want to ruin the paint getting them off obviously.
Thanks in advance everyone!
Greg
Old Sep 26, 2005 | 01:33 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
Originally Posted by gbjork50
Hi!
Greg
Just take a blow dryer to an edge and heat it up, then pull gently. Should come right off like that
Old Sep 26, 2005 | 03:15 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
Awesome! Thanks!!!!!!!!!!!!!!!
Old Sep 26, 2005 | 03:27 PM
edensknight's Avatar
edensknight
Another vote for the high heat of a handheld hair dryer. Take your time when lifting the letters so that you do not end up cracking and lifting paint. Good luck.
Old Sep 27, 2005 | 12:02 AM
SonoraVette's Avatar
SonoraVette
Default Removing Letters
Soften them up with the blow dryer, then pull a piece of fishing line slowly past the back of each letter going through the adhesive. Use a little adhesive remover to clean the excess, then do a final cleaning of the area with some rubbing alcohol and you're good to go with the new ones -
To HELP- Removing rear/front letter inserts
