2001 Cd 12 Pak
Old Sep 27, 2005 | 03:08 PM
BOBBIE's Avatar
BOBBIE
Default 2001 Cd 12 Pak
I Have A 2001 With A 12 Pak Cd In The Trunk. My Problem Is
I Can Hear It Changing In The Rear But It Does Not Register Or Play Thru The Radio ?? What To Do ?
Old Sep 27, 2005 | 03:10 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
mine did that once, all I did was remove the cartridge and put it back in.
It went through and loaded all the cd's and has worked great since.
Old Sep 27, 2005 | 03:58 PM
1KLRTOY's Avatar
1KLRTOY
Make sure the CD's are loaded with the lablels facing the right way, if there wrong it will change but won't play,no harm in checking
Old Sep 27, 2005 | 04:03 PM
BrianWe's Avatar
BrianWe
Check the labels. If they are in correctly and you can see an ERR message on the in-dash cd player right after you hear the shuffling stop, your changer is probably dead. I think they are very low quality. I have gone through 3 already on my 2004.
Old Sep 27, 2005 | 04:19 PM
jawzforlife's Avatar
jawzforlife
My CD changer died too. I'm changing to a MP3 player.
Old Sep 27, 2005 | 05:33 PM
rcs128's Avatar
rcs128
They also seem finicky about playing homemade CDs. If you're not already doing so, try it with real store-bought CDs and see if they work.
Old Sep 27, 2005 | 06:08 PM
C5Jim's Avatar
C5Jim
Check the CD's. You may have one loaded wrong. They need to loaded in upside down.
Good luck.
To 2001 Cd 12 Pak
