High Beams ?????????????
Old Sep 27, 2005 | 09:40 PM
jmesox's Avatar
jmesox
Default High Beams ?????????????
When the High beams are on should the low beams also be on??? On my Pontiac all four beams are on. I just noticed on my Vette that only my high beams are on. I think there may be a problem with the switch.
John
Old Sep 27, 2005 | 10:12 PM
Medivh's Avatar
Medivh
No, Chevrolet in their wisdom made it this way. There is a module you can get to make them work together, but nobody on here seems to know how to wire it in. And i havde not been able to figure it out.
Old Sep 27, 2005 | 10:13 PM
David Garren's Avatar
David Garren
no that is normal. it's the same on my silverado and trailblazer
Old Sep 27, 2005 | 10:39 PM
BigJoe's Avatar
BigJoe
If you hold the dmmer wand in the up position (toward you) all 4 stay on. Good for short times when you need a bit more light.
Old Sep 27, 2005 | 10:51 PM
Baron138's Avatar
Baron138
I wish the General didn't do this. My Avalanche was the same way. I bought an after market relay that I wired in, and all 4 stay on together now. I think the company was R & D. I have to look in my file. I should contact them, maybe they have one for the C5. If not it would be a good project for them.
Old Sep 28, 2005 | 06:13 AM
ebubman's Avatar
ebubman
don't you just love it when the high beams are on? bub
Old Sep 28, 2005 | 06:40 AM
Didn't know this - guess I never thought about it. Doesn't make a whole lot of sense to me that the low beams would go off. I know the fog lights turn off when the high beams are on.
Old Sep 28, 2005 | 10:37 AM
Wah's Avatar
Wah
It's actually a good thing.
The export versions come with real headlight bulbs (i.e. H4) and it's a dual-filament configuration. If both filaments are powered at the same time, the bulb will overheat and then fail quickly.
Old Sep 28, 2005 | 04:26 PM
Medivh's Avatar
Medivh
I just figured out to add a relay switch in to make the lows stay on when you turn on the high beams. If anyone wants to know, shoot me an email.
Ptrue81@yahoo.com
To High Beams ?????????????
