Brake paint
Old Sep 29, 2005 | 03:28 PM
Elpelon's Avatar
Elpelon
Everyone has a different approach but do not use any type of high-speed rotary device. You can wind up taking off too much metal.
Paint the whole rotor including the letters.
What I used and worked great was one of my wife's emery boards. It is the same principle as sand paper but is stiff so you can gently move it back and forth and wind up with a perfect job. I cut the board shorter then just used it like you would a sanding block.
Hope this helps
Old Sep 29, 2005 | 08:29 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I painted mine white. Check my avatar.
Old Sep 29, 2005 | 08:54 PM
SRQC5's Avatar
SRQC5
razor blade works fine...
