D*mn passenger window!
Old Sep 30, 2005 | 09:23 AM
TurB0ve#E's Avatar
TurB0ve#E
Default D*mn passenger window!
I have this problem. A few days after I bought the car, the passenger window decided it didn't want to go down, a few days later out of the blue it started working again. Now 2 months later the same damn thing is happening... it doesn't want to go down!! I hear clicking in the door like the power is getting from the switch to the window but it still won't go down. Any help would be appreciated. The first time it happened, I took off the door panel and felt the window motor it was hot as hell but after a few days it just started working. I haven't taken off the door panel again to check it out so I don't know if it is hot again or if it is suppose to be hot all the time. Anyone else had a problem like this?
Old Sep 30, 2005 | 09:38 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yes, although mine went out and stayed out. Fortunately have GMPP and dealer replaced the motor............
Old Sep 30, 2005 | 10:04 AM
I wouldn't think the motor should be hot if it is not being used. Sounds like a defect with that motor. Maybe a replacement is in order or at least have it checked to see if there is a short or something in it.
To D*mn passenger window!
