Wheel Offset Question
Anyone know if this will be a problem especially if the drivers side front wheel has the 58 offset?
It sounds like you got a reproduction wheel. That 2mm offset difference means the replacement 56mm wheel will stick outwards a measly 0.078" (or approx 1/16") further, not something you'd notice visually, but it will throw the car's alignment out of whack by that much. The +56 offset itself is fine, but I don't think it's a good idea to mix offsets side to side.
Personally, I would either find an original wheel to replace it with, or replace both front wheels with the +56 wheels.
