I noticed that my z06 (gunmetal stock) wheels are curb rashed from the last owner. i'd like to repair them myself using the much touted "nasa method"- but i have no idea which paint to use. i would like to match it as close as possible. is there a gm paint code for these wheels?
The Z06 wheel paint is called Light Gray Metallic with code # WA9789. I have not seen it available at the dealers or through some of the vendors like Ecklers, etc. I special ordered mine through Paintscratch.com and you could also try Automotivetouchup.com. You should get a bottle of the clearcoat to put on after the touch up. FYI.
