Battery help please!!
Old Oct 3, 2005 | 02:48 PM
More Toys's Avatar
More Toys
4th Gear
Default Battery help please!!
I need some help. If I leave my car sit for a few weeks, the battery dies.
I read a post here about a similar issue, and there was a response posted that told how to test to see if the battery was draining when the car is turned off. Something about a volt meter and disconnecting the positive terminal. They also told which fuse to pull to test if it was the power seat draining the battery.
I can't relocate that post, so if someone would be so kind to tell me how to test it again, it would be appreciated. Thanks.
Old Oct 3, 2005 | 02:52 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
http://forums.corvetteforum.com/show...g&forum_id=103
Good Luck
Old Oct 3, 2005 | 05:06 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If you let the car set for weeks, the battery is going to die.
Get a battery tender.
I have the Deltran waterproof battery tender, it can be purchased for around 25 bucks.
Old Oct 3, 2005 | 05:16 PM
I agree.
To Battery help please!!
