Question about front rubber nose
Old Oct 4, 2005 | 08:30 AM
TomZ's Avatar
TomZ
Default Question about front rubber nose
As I was walking away from my Vette this morning in the parking lot, I noticed a barely noticeable small "dimple" (all in all about an inch in diameter) in the front rubber nose. The paint is not broken, and I'm wondering if maybe the front nose "flexed" due to some reason (or if the rubber isn't always shaped perfectly)..? I didn't notice this up until now, and I doubt that it was hit between last night and today. Is this a normal anomaly (and yes I'm being ****)?
Old Oct 4, 2005 | 08:31 AM
TomZ's Avatar
TomZ
Actually the word "dimple" is too harsh; it's more like a depression. But the whole area flexes being that it's rubber..
Old Oct 4, 2005 | 08:37 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
You are speaking about the BLACK rubber air dam, yes??
All thee pieces are easily replaced at low cost. Not to worry!! They won't be perfect unfortunately, and the outside ones rub all the time getting frayed edges, blah-blah-blah... but it is needed to help push the air up into the radiator.
Have a good day!! To early for a "cheers", sorry...
Old Oct 4, 2005 | 08:39 AM
TomZ's Avatar
TomZ
No -- I was actually talking about the front nose (i.e. the one that the emblem rests on).. I didn't hit anything and noone hit me -- I'm just wondering of a little flexing in the rubber in some kind of imperfection..?
Old Oct 4, 2005 | 08:42 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Ahh.. my bad... I saw the word "rubber" and assumed... Now I feel like an A$$...
Sorry...
Old Oct 4, 2005 | 08:45 AM
TomZ's Avatar
TomZ
No biggie.. I just am wondering if this is a common occurrence, or what else would cause such a depression in the rubber.
Old Oct 4, 2005 | 09:28 AM
falconfling's Avatar
falconfling
Sounds like someone gently, very gently, backed into it. Sort of like a giant hand just pushing it in. Maybe even stayed against it long enough for the indentation to "take" in the plastics memory.
Old Oct 4, 2005 | 09:36 AM
TomZ's Avatar
TomZ
But there is not even a hint of a scratch or abrasion.. Hmmm. I had someone back into the rear end of a '96 Z28 that I used to have, and the body shop used a heat lamp. Voila, the indentation was gone!
Old Oct 4, 2005 | 09:39 AM
mike348's Avatar
mike348
Mine has very slight waves but no dimples.
Old Oct 4, 2005 | 09:45 AM
sailohio's Avatar
sailohio
Default You got a rubber nose?
Tom, I've seen that before. I think it is an imperfection from the molding process of the nose piece. There isn't much you can do about it. If you wanted to be adventuresome, you could pull the cover off and try to reinforce it from underneath. I almost bought a 2000 Vert which had some of that in the lower front side bumper cover. I had a body shop man look at it and he said the only way to be 100% sure of fixing it was to replace that piece. He said he could make it look better but not eliminate the dimples. You might want to have a good body shop man check it out. All cars have plastic bumper covers today. The body shop guys should be familiar with fixing them. Good luck and sorry about the rubber nose joke.
Old Oct 4, 2005 | 12:52 PM
TomZ's Avatar
TomZ
It's almost like a wave or a slight ripple (can't feel it when I rub my fingers over it).
Thanks everyone.
To Question about front rubber nose
