How to clear ECU codes?
Old Oct 5, 2005 | 12:33 PM
Riggs's Avatar
Riggs
Default How to clear ECU codes?
Well, I have written them all down...
Now, how do I clear them...
I had several, but almost all of them had "H" in front of them which I believe means history...
How do I delete them so I can go back and check the new codes after I drive the car for a couple of days..
Regards,
Riggs
Old Oct 5, 2005 | 01:33 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
You apparently know how to see the codes so:
Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode.
It should start with a module and show "NO CODES" or "# CODES".
To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES".
Press OPTIONS to go to the next module. Repeat until you have reset the codes in all the computer modules
Old Oct 5, 2005 | 01:42 PM
Riggs's Avatar
Riggs
Worked, thanks!
To How to clear ECU codes?
