Looking for recommendations...Intake systems...
Old Oct 6, 2005 | 02:15 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Default Looking for recommendations...Intake systems...
I know, I know. This topic is like BSM's or no BSM's...Which exhaust is best?...Zaino or Meguiars?...etc etc...
But I actually haven't seen this one at all lately: Which intake is best and why? Got the exhaust and X pipe on the way, I've done the whole tire/wheel/ceramic pad/drilled rotor thing, now it's time to plan on getting a good intake system.
Recommendations, anyone? Which one gives the most bang for the buck?
TIA
RR
Old Oct 6, 2005 | 02:18 AM
slverc5's Avatar
slverc5
I've been hearing good things about Halltech stingers or Halltech TRAP ( don't know if they are the same). That's most likely what I'm going to get anyway.
Old Oct 6, 2005 | 02:20 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Hey Red
My exp. has been nothing short of fantastic with the Donaldson BlackWing.
PROS:
1. I felt better throttle response almost immediately.
2. It goes for a long while between cleanings.
3. Easy install.
4. Around $220.00
CONS:
No C.A.R.B. #
Good luck with your search
Dave Q.
Old Oct 6, 2005 | 02:24 AM
ExRedRacer's Avatar
ExRedRacer
Originally Posted by MyVetteDream
Hey Red
PROS:
3. Easy install.
4. Around $220.00
CONS:
No C.A.R.B. #
Dave Q.
Hi Dave,
That CARB thing is for Cali drivers, only, right? It does look like Washington state is going to adopt Cali pollution regs in the next few years... And how do you clean the filter?
Thanks...
RR
Old Oct 6, 2005 | 02:29 AM
MyVetteDream
Originally Posted by Red Racer
Hi Dave,
Thanks...
RR
Re: CARB- I believe so.
Cleaning:
Remove it.
Lightly brush the big debris off.
You can clean it with a BlackWing Cleaning Kit or...
Use Simple Green. Spray it on. Let it soak for about 15 minutes (have some suds).
Hose it off from the inside out.
Let it dry completely (Have some more suds)
Lightly oil, replace it and have some suds!
Fall down.
Old Oct 6, 2005 | 02:38 AM
LS9's Avatar
LS9
CONS:
No C.A.R.B. #
that's why I kept the stocker since you can swap them out in 5-10 minutes
ExRedRacer's Avatar
ExRedRacer
Cleaning:
Remove it.
Fall down.
Sounds easy enough...thanks for the response
Neck/shoulders/arm feeling better?
Old Oct 6, 2005 | 02:42 AM
MyVetteDream
Anytime. Yes sir. Thanks.
Old Oct 6, 2005 | 02:44 AM
MyVetteDream
Definitely a good decision.
Old Oct 6, 2005 | 02:49 AM
1STDROP123's Avatar
1STDROP123
Default Intake
THE K&N IS FANTASTIC BUT A PAIN TO INSTALL I AM GLAD ITS IN AND LOVE IT BUT WOULD NOT WANT TO INSTALL A SECOND TIME .
Old Oct 6, 2005 | 03:01 AM
edensknight's Avatar
edensknight
Another vote for the Blackwing.
Old Oct 6, 2005 | 03:43 AM
xjcharity's Avatar
xjcharity
St. Jude Donor '21
I still have my Blackwing, it is an excellent filter. I wanted to try the Vararam and never looked back.
The Vararam pulls harder than the Blackwing, I've used both. The Blackwing was nice but I chose the Vararam.
Old Oct 6, 2005 | 08:42 AM
Dark-Knight's Avatar
Dark-Knight
Have you checked out the Hurricane? Ram effect with out the worry of vapor lock...
http://www.westcoastcorvette.com/sho...il.cfm?id=1148
Old Oct 6, 2005 | 08:47 AM
jrose7004's Avatar
jrose7004
I've got a twin cone K&N system and like it alot!
Old Oct 6, 2005 | 08:48 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Went with the Stinger. Good value, and then I added the Z06 fuel rail covers to match.
To Looking for recommendations...Intake systems...
