[Z06] hole in floor
Old Oct 7, 2005 | 02:17 PM
R1maniac's Avatar
R1maniac
7th Gear
Default hole in floor
I have a 01 z06 and somehow got a hole the size of a golfball in bottom wooden floor pan. I was wondering how to fix this? I was thinking joint compoud or drywall mud. thanx
Old Oct 7, 2005 | 04:11 PM
C6~Missle's Avatar
C6~Missle
Wow... they make that plastic wood filler.. or a piece of wood and some liquid nails...
Old Oct 7, 2005 | 04:35 PM
HP_Addict's Avatar
HP_Addict
fiberglass w/epoxy reisn
Old Oct 7, 2005 | 07:23 PM
Solofast's Avatar
Solofast
You want to make sure that you absolutely keep water out of the balsa. If it has gotten wet you need to get it dried out thoroughly before you repair it. Then you need to make sure that you have a watertight repair with glass and resin, and then coat it with a sealer to make sure it won't leak.
If the wood has water in it when it is resealed, when it gets hot it can expand and cause delamination that would be a mess...
Dry it out and properly repair it, this is no place for cheap putty or half-azzed repairs.
Old Oct 7, 2005 | 07:58 PM
R1maniac's Avatar
R1maniac
7th Gear
like this http://www.bondo-online.com/catalog_...sp?itemNbr=480
Old Oct 10, 2005 | 11:15 AM
HP_Addict's Avatar
HP_Addict
I could not link the page so I copied the info below. It is from www.mcmaster.com . I like using the epoxy based resin instead of the poly resin. Th eepoxy resin sticks better. If you use the poly resin be sure to rough up the surface with sandpaper to give something to stick to. I would lay a couple strips of glass on the bottom. Fill the hole with resin, then lay a few layers on the top. If you want the bottom to look good when done oyu will have to sand and paint it. Any body shop should be able to fix this for you.
West Systems Epoxy Repair Kit
Click to change image size High strength and superior moisture resistance make this kit good for repairing fiberglass (FRP), especially in marine applications. It bonds wood, some metals (including steel, lead, aluminum, and stainless steel), and some hard plastics (including PVC and ABS).
Kit contains six 16-gram packets of 105-A resin, six 3.2-gram packets of 205-A hardener, 4 grams of 406-2 high-density filler, 9 grams of 407-5 low-density filler, two application brushes, four mixing sticks, four mixing cups, four cleaning pads, two pipe cleaners, a 4" x 12" fiberglass cloth, a syringe dispenser, and disposable gloves. Begins to harden in 9-12 minutes; reaches full strength in 1-4 days. Mix ratio is 5:1. Color is amber.
Each
101-6 Repair Kit
7480A31 $25.96
Repl. 406-2 High-Density Filler (1.7 oz.)
7480A33 7.36
Repl. 407-5 Low-Density Filler (4 oz.)
7480A34 12.55
Repl. 101-T Resin and Hardener
(6 packets of each) 7480A32 Per Set $17.13
Additional West Systems Items
West Systems No. Size Each
105-A Resin 1 qt.
7480A41 $29.35
205-A Fast Hardener 0.44 pint
7480A42 14.02
206-A Slow Hardener 0.44 pint
7480A43 14.02
406-7 High-Density Filler 5.5 oz.
7480A44 20.38
300 Mini-Pump Dispensing Set (set of 3) 7480A45 Per Set $11.76
732-10 Fiberglass Cloth (4" Wd. x 10' Lg.) 7480A46 Per Roll $11.35
Old Nov 7, 2005 | 04:25 PM
Bill Dearborn's Avatar
Bill Dearborn
Given the structural integrity required from that part (supports the seat and is part of the safety restraint system) I would replace it if the Balsa wood inside got wet. There is no way to know how badly damaged it is. Water and wood do not go well together.
Bill
Old Nov 7, 2005 | 11:52 PM
l2vette's Avatar
l2vette
Good advice!!
To hole in floor
