tire pressure ?
Oct 8, 2005 | 08:02 AM
tire pressure ?
Help!
I dont have a data decal on the drivers side door or the sill
for vehicle loadiing or tire pressures.
What is the recommended pressures frt/rear?
Thanks in advance, I thought I could find it in the O/M, but
it refered me to the missing data plate
Oct 8, 2005 | 08:03 AM
CI 6-7-8 Veteran
St. Jude Donor '09
30 psi cold, all the way around.
Oct 8, 2005 | 08:14 AM
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Quote:
Dawgs got it.
Oct 8, 2005 | 08:58 AM
Question...
Do you think with the runflats...It would ride a little better with like 32 psi..(to get it more off just the sidewall?)
Oct 8, 2005 | 09:38 AM
Quote:
As said before... 30 psi cold. Rolling (warm)... 32-33 psi. The psi will go up 2 to 3 psi once you start rolling. That should be it.
