Cleaning up Bear Eradispeed Rotors
Old Oct 12, 2005 | 11:50 AM
CUlookin's Avatar
CUlookin
Default Cleaning up Bear Eradispeed Rotors
I posted this over in Car Care products but don't think it really classifies under detailing and waxing... So I'll post it over here too
Anyway, I've had my 2 pc. Bear Eradispeeds for about 6 months now and have about 2k miles on them. I pulled my wheels off last night to do some work and noticed that the slots and holes have brakedust buildup in them. I tried to wipe it out with a rag to no avail. I'm entering my car in a fun show on saturday and would really like them to sparkle without removing them from the car, sanding them, and painting them with either silver or clear piant... Any suggestions are appreciated!
Old Oct 12, 2005 | 12:02 PM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Do not paint them. As soon as you apply the breaks the paint will come off . They will look worse.
Old Oct 12, 2005 | 12:10 PM
vette 85's Avatar
vette 85
I bought a small household steam cleaner from Target for like 60 bucks. One tank of water per side, depends on the build-up. It works great! No abraisives just water.
Old Oct 12, 2005 | 12:11 PM
CUlookin's Avatar
CUlookin
I was referring to only the slots and holes... I've read Evil-Twin's writeup about his process of basically stripping the rotors down and painting everything with high temp clear paint to keep them from rusting but I don't have the time to do this. Anyone know a way to get the buildup out of the slots and holes, like a certain cleaner or process?
Old Oct 12, 2005 | 12:18 PM
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
Hey Rob,
CRC Brake Parts Cleaner in the red spray can (Pep Boys, AutoZone) works well for the initial cleaning. If you want to really make them bling paint the slots and dimples with some VHT high temp paint Follow this write up
Gary
Old Oct 12, 2005 | 12:54 PM
SGT. PYLE's Avatar
SGT. PYLE
I used a wire brush and scrubbed the hell out of mine to get the build-up out of the slotts and holes. It will remove the the build-up but you will probably want to use some brake parts cleaner to get them really looking sharp . Good Luck.
Old Oct 12, 2005 | 01:17 PM
vette 85's Avatar
vette 85
The wire brush will remove the zinc coating as well the brake dust, that's why I use the steam cleaner. When you get to the show an acid brush just to them touch-up.
Old Oct 12, 2005 | 01:30 PM
I just finished detailing my car last week and what I did was take some fine steel wool and used it to clean out the slots and holes in my Eradispeeds. Made a world of difference.
Old Oct 12, 2005 | 04:00 PM
CUlookin's Avatar
CUlookin
Originally Posted by GB Vette
Hey Rob,
Gary
Damn you Gary, why did you have to go and post that picture again... It makes me so jealous...
Anyway, I've heard that the Brake Parts cleaner will take off the powdercoating on my Z06 calipers... is this true?
P.S. Will the CRC cleaner or really fine steel wool take off the Zinc coating on the rotors?
Thanks for the replies guys!
Old Oct 12, 2005 | 04:26 PM
edensknight's Avatar
edensknight
Those are some beautiful wheels and brakes.
Old Oct 12, 2005 | 04:30 PM
Jetspeedz's Avatar
Jetspeedz
brake cleaner then after simply green and lots of time.. but who cares about the holes, after a few mins of driving ur back to square one
Old Oct 12, 2005 | 06:02 PM
scaperman's Avatar
scaperman
What about a dremmel tool with the fine wire brush attachment
Old Oct 12, 2005 | 06:19 PM
CUlookin's Avatar
CUlookin
That's part of Evil-Twins protocol but I don't want to have to pull off the rotors and paint 'em haha. I'm going to just clean them up the best I can with some CRC and this winter I will pull them off and paint them. Thanks again for the responses!
Old Oct 12, 2005 | 07:53 PM
Dr. Dan's Avatar
Dr. Dan
The brake cleaner removes the zinc coating on the rotors and they rusted. Had to have them re-Zinc plated. $25 apiece.
Old Oct 12, 2005 | 08:15 PM
doug doo wop's Avatar
doug doo wop
just use simple green and a stiff tooth brush or scrub brush.
Old Oct 12, 2005 | 08:47 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
Same with StuzVette...
...I used dremel bits with 2 shaped tips to sand out each hole then a steel wire brush on my drill to clean the slots...
...no paint...
I have pics somewhere...
Old Oct 12, 2005 | 09:02 PM
StuzVette's Avatar
StuzVette
found them...
...now if I could just find the finished product...
To Cleaning up Bear Eradispeed Rotors
Old Oct 12, 2005 | 09:40 PM
KARSC5's Avatar
KARSC5
Hey Rob,
Gary
Gotta love GB's pics
Old Oct 12, 2005 | 09:54 PM
iceburgh's Avatar
iceburgh
St. Jude Donor '03-'04-'05-'06-'07-'10
Hey Rob,
Gary
Did the same thing...works like a charm
Old Oct 12, 2005 | 10:04 PM
Evil-Twin's Avatar
Evil-Twin
Some 00 grit steel wool, found in the paint department of Home depot, and a paint stirring stick/..///
put the steel wool on the end of the rounded part of the stick...
run it up and down the slot, like trying to start a fire with a wooden stick... the slot will shine like crazy it takes about five minutes to do one rotor...thats for the slot... you need some 60 grit emery paper for the holes...and a dremel... you can do the holes "On the car in five minutes.. this will last a little while without coating them... but when you use a dremel with emery paper.. those holes will look like diamonds..you will also make the rotors stronger, because you are putting a radius on the holes, this will relieve heat stress at the hard angles of the holes...
Any process to remove the baked in brake dust will also remove any zinc coating that remains in the holes or slots...
you can use the steel wool on the outer edges of the rotor to remove rust also...
These front rotors have over 50,000 miles on them in this picture. They are the first set of two piece Baer Eradispeeds in the country. Car is sitting high because it just came down off jack stands.
