LED Tail Light Blinks Too Fast - Help
When you splice the LE into your signal wire... it'll fix that issue.
Dave Q.
Dave Q.
Wonder why that would occur?
I have LED's from superlumination that are the tower style in front(Amber LED) turn signal/driving lights and the rear(Red LED) brake lights. I tried several combinations with load equalizers which get hot. The main point of getting LEDs for me was less load on the electrical system. LED's are much more efficient, they do not require more voltage, they require less current. The reason the load equalizer is needed is to maintain the higher level of current flow through the flasher unit. The flasher will flash at the fast rate, when a normal bulb is burned out, or you use an LED light in its place. Some new type flashers do not do this. But.....
The flasher unit is not easy to change without taking the dash apart. And it is located in the emergency flasher switch. You have to change the whole switch if there is a even an aftermarket replacement, which I have yet to find. When I had just the rear LEDs installed the emergency flashers worked fine, but the turn signal was fast, now everything is flashing fast. LEDs do react faster than incandescent bulbs, the LEDs come on instantly and get your attention.
I just live with it fast. I liked the fact that less load on the electrical system, means slightly higher more consistant voltage to the fuel system pump and injectors. Volts read 14.1 instead of 13.9 on DIC and is steady while braking where as before, you hit the brakes and watch the voltage drop to 13.8. Granted that is really nothing to worry about, but every little bit helps.
BTW, I have considered just going back to the normal bulbs, but I kind of got used to it.
http://www.telstar-electronics.com/F...t%20Manual.pdf
but dont think it will due to corvettes unconventional wiring..
a flasher. Bought the flasher from Auto-Zone (Tridon EL-12). I still have the regular incandescents in the front and have LEDS in all four tail-lights (from Ledtronics). Each of the Ledtronics LED lights have 24 LEDS. The EL-12 flasher now controls only the rear lights. Everything flashes normally. HTH
Do you have a link or part number for the adjur piece?
where does it install?
How much is it?
Thanks for the help
If you want to skip the rest of this thread heres my writup with the answers
http://forums.corvetteforum.com/show...post1552668525
Can't do that on a C5. Flasher is integrated into the hazard switch. It isnt your typical plug in flasher you can get at Pep Boys.
How much is it?
Thanks for the help
